rok.palash | 08-17-2014 09:36 | Quote:
Originally Posted by 007vivek007
(Post 10500561)
Have you tried travelling in a roaming zone? Give it a try when you move to a roaming zone. You will definitely face activation loops.
The best way to get rid activation loops to set network mode "Manually". That's it! No need of any patch. It will perform the same thing that your patch does. You will not face activation loops in a home circle at least even you will get "No Service".
The best scenario is when you don't get the activation loops even while entering to a roaming zone. | Yes I have tested it with traveling and before this patch was released, you would lose signal when your carrier is in process of changing the base station. Even if you set network to "Manual" mode you would still face activation loops when changing the base station. But with the patch installed "correctly", the issue of loops has completely gone and is 100% stable no doubt in that.
Do try and you would notice great improvements in stablity.
Hope this helps.
Thanks. |
