Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-08-2014, 16:11   #271 (permalink)
Member: 1938435
Thanks Meter: 208
Not doing Sprint 5S/5C anymore due to another dispute with them. I'm tired of being f-ed by them. Why not just jailbreak? RSIM + jailbreak/iFile provides the same benefit as Sprint activation. I'll provide it again when the jailbreak is patched.
Old 07-08-2014, 19:17   #272 (permalink)
Member: 1848921
After renaming carrier bundle 3g working perfectly,sms and OG calls also but while incoming it says out of coverage area even with full network.
Install ir0se tool and force 2g then its working fine but then network issue is coming like voice cracking and call dropping.
So renamed carrier lab bundle to sprint again and its working fine but internet and sms not working.
Any solution for it.
Also is there any solution for activation booting as while no network or poor network its jumping to activation screen.
Pls help
Im using r-sim air2 with 7.1.1 jailbroken with Pangu.
Old 07-08-2014, 19:25   #273 (permalink)
Member: 1938435
Thanks Meter: 208
Only way to avoid activation screen is to delete setup.app, but that will result in no incoming calls or SMS on 7.1.x. Try Gmail to fix 3G incoming issue. Change Push to Fetch. Make sure WiFi is always off. It should have more network stability this way.
Old 07-08-2014, 19:32   #274 (permalink)
Member: 1848921
How to do gmail from puch to fetch pls suggest
Old 07-08-2014, 19:37   #275 (permalink)
Member: 1938435
Thanks Meter: 208
Go to Seeings, Mail, Push, Off. Fetch interval might have to be lower than 15 minutes. This will fix incoming texts(with up to 1 minute delay), but it won't fix incoming calls.
Old 07-08-2014, 19:43   #276 (permalink)
Member: 1848921
Need incoming calls for that is there any update with rsim or any cydia tweaks????
Thats why i requested for sprint activation
Old 07-08-2014, 20:18   #277 (permalink)
Member: 1938435
Thanks Meter: 208
Even in Edge mode, no incoming calls?
Old 07-08-2014, 20:50   #278 (permalink)
Member: 1848921
While edge mode incoming working but network issue like call drop and voice crack issues are there. But on sprint carrier bundle with ir0se tool works great
Old 07-12-2014, 10:10   #279 (permalink)
Member: 2118020
news?
Hi SimTester:
I'm a owner of iphone5 ios7.0.6 JB rsim8+ and 128k Sim.
Everything's working fine except 3g (only edge).
As I've stopped following you guys for a while, I wonder if somithing's changed meantime.
Thank you!
steve
Old 09-22-2014, 18:19   #280 (permalink)
Member: 1938435
Thanks Meter: 208
This service discussion has been moved to the GPP & Gevey support forum and now supports 5C & 5S although we have to try its effectiveness.
Old 09-22-2014, 18:46   #281 (permalink)
Finn's Avatar
Member: 7731
Thanks Meter: 27
Link for the discussion?
Old 09-22-2014, 20:57   #282 (permalink)
Member: 1811083
Thanks Meter: 14
Pls can we have the link
Sent from my iPhone using Tapatalk
Old 04-09-2015, 02:21   #283 (permalink)
Member: 1811083
Thanks Meter: 14
Hello. Pls can this service be restarted
Old 04-10-2015, 21:06   #284 (permalink)
Member: 1938435
Thanks Meter: 208
Sprint stopped doing prepaid activations for a lot of phones, so I stopped offering it.
Old 04-10-2015, 21:20   #285 (permalink)
Member: 1811083
Thanks Meter: 14
Wow. Upgraded by mistake and stuck or is it possible to check if the phone is clean ( unpaid bills blacklisted etc)
Page generated in 0.51447 seconds with 8 queries
