Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 06-19-2014, 20:56   #211 (permalink)
Member: 2207785
I have an iphone 5s locked to the japanese AU KDDI operator under ios 7.1.1
I bought from ebay a r-sim mini 2 to unlock it but it seems i got a broke r-sim because no popup and no sim applications section in settings > phone
but i discovered something very intersting that could help some of you.
I remove the r-sim and got my iphone partially unlocked thanks to irosetool by forcing 2G
call in and out working
sms in and out working
edge ok
all this without the r-sim
is it normal? and who can help to further unlock and get 3G/4G working
Old 06-30-2014, 06:51   #212 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
where you buy this iphone ,it is normal if you buy from china,
Old 06-30-2014, 06:53   #213 (permalink)
iamtj's Avatar
Member: 2048052
Thanks Meter: 18
edge around the world
Sent from my iPhone using Tapatalk
Old 07-02-2014, 09:50   #214 (permalink)
Member: 2187459
1.Will this patch work 7.1.2 for any iphone above 4 models
2. I have installed the patch my number is unknown (Settings>Phone>My No : Unknown) but when i install chat app(most of the apps), the apps tells that sim detected as Netherland but i live in INDIA will this problem can be solved?
3.Solution for My no: Unkown (Settings>Phone>My No : Unknown)
Old 07-02-2014, 14:14   #215 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
patch can work 7.1.2 for any iphone
Old 07-03-2014, 14:59   #216 (permalink)
Member: 2187459
How to solve unknown phone no (Settings>Phone>My No : Unknown) by using the patch
Old 07-08-2014, 18:13   #217 (permalink)
Member: 2160880
Thanks Meter: 17
R-SIM mini2 has a BIG BIG BIG issue when 3G enabled.
When 3G enabled, incoming calls FAIL AND when travelling abroad the signal get lost and then the SIM INVALID message shows.
Firmware is not stable yet with 3G enabled. AND sometimes is not stable with 2G. Incoming calls with 2G (Edge) works good but when traveling it crashes and loose signal.
When will you update the firmware to fix these issues ?
Old 07-10-2014, 11:47   #218 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
operational approach RSIM 9 PRO mini air,R-SIM8+,SAMSIM,3G,R-SIM5+,R-SIM6,RSIM5+,RSIM6,RSIM7,R-SIM7+?Unlock,iPhone5,iPhone4S,Firmware,Any version, No jailbreak
Old 07-12-2014, 00:12   #219 (permalink)
Member: 2160880
Thanks Meter: 17
Miliky, Do you say that with the patches will not loose signal and have 3G ???
Old 07-12-2014, 07:48   #220 (permalink)
Member: 73854
Tried many times but was NOT able to get 3G working on my iPhone 5S 128k SIM locked to SB japan.
Hope RSIM team will give us a working fix.
Old 07-15-2014, 06:11   #221 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
post some pictures about your phone here ,thank you !
Old 07-16-2014, 08:07   #222 (permalink)
Member: 2118183
need to buy activation code fast
Old 07-16-2014, 17:03   #223 (permalink)
Member: 814915
Question about 3G patch usability
Hello all, for the LTE patch to work is it necessary to have the device jailbroken?
I have 7.1.2, no jailbreak yet, and although I activated the LTE patch, 3G still doesn't show up, only Egde...
Txs,
LM
Old 07-16-2014, 21:11   #224 (permalink)
Member: 2223788
hi, I've bought a R-SIM Air to unlock my Iphone 4s 7.1.2 SPRINT for european carrier but I Always receive Invalid sim. I'd like to use the patch but I do not know where I can retrieve the activation code. thanks
Old 07-18-2014, 18:52   #225 (permalink)
Member: 2212320
Can someone please explain to me the purpose of this patch and how to use it on a USA sprint iPhone 5, switching to straight talk AT&T sim.
Page generated in 0.19410 seconds with 9 queries
