Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 04-15-2014, 06:32   #136 (permalink)
Member: 2168237
Originally Posted by futur View Post
If you mean the patch with the activation code then the answer is no but neither the free one will fix it for you unless if your iphone is jailbroken,
My iphone 5 ios 7.1 is activated using rsim 9 pro, but no signals for calls.
Please let me know if the new rpatch can fix this.
Thanks
Old 04-15-2014, 11:55   #137 (permalink)
Member: 2047874
Originally Posted by ymtong View Post
HOW TO GET FREE PATCH and install guide
1. you must have itools (download link) OR IFUNBOX
Have more easy way to install...only go to unlockpro.ru/nano4g from iPhone and install
Old 04-15-2014, 17:25   #138 (permalink)
Member: 2160880
Thanks Meter: 17
You need to mention that jailbreak is needed in order to install using itools.
iOS 7.1 won't allow to install from unlockpro.ru/nano4g
Old 04-16-2014, 02:08   #139 (permalink)
Member: 2168237
I was able to download ir0se from unlockpro on my iphone 5 ios 7.1 and patch 2G and 3G and restarted. Chinasnow is verified in the profile.
Thanks paveluoker and yntong.
But still no service.
What to do.
Old 04-16-2014, 06:58   #140 (permalink)
Member: 1938435
Thanks Meter: 208
No service but you get calls, right? No outgoing SMS or internet? I can fix internet only if you have a clean MEID: swappa.com/esn $20 fix takes 5 minutes.
Old 04-16-2014, 07:07   #141 (permalink)
Member: 276082
Thanks Meter: 113
What to do.
Your iphone lock to which country and network?
Did you try run irose and force 2G?
Old 04-16-2014, 09:30   #142 (permalink)
Member: 2168237
Originally Posted by SIMTester View Post
No service but you get calls, right? No outgoing SMS or internet? I can fix internet only if you have a clean MEID: $20 fix takes 5 minutes.
No calls. No service. No incomming or outgoing calls. Yes, MEID is clean.
Old 04-16-2014, 10:05   #143 (permalink)
Member: 2168237
Country is Canada. Locked to Sasktel.
Yes I did run ir0se and force 2G.
No service. Can't receive or make calls.
Old 04-17-2014, 22:34   #144 (permalink)
Member: 972132
Sonork: phantitoxp
Thanks Meter: 4,294,967,295
iphone 5
i have a i5 ATT with rsim 9 pro i got cellular signal all works but no 2g/3g no data is working, i try ir0se and nothing, i think the apn on the phone is wrong and att dont let me edit the apn settings, whay are my options here?
Old 04-18-2014, 21:16   #145 (permalink)
Member: 2170565
Will this Rpatch work with Verizon 4s ios7.1
I have R-sim mini+ plug and play, but it shows "Bad SIM" after I install. Will this Rpatch fix this problem?
Old 04-18-2014, 21:23   #146 (permalink)
Member: 1938435
Thanks Meter: 208
unlockit.co.nz in Safari
Old 04-18-2014, 22:20   #147 (permalink)
Member: 2100051
Thanks Meter: 14
from safari on phone go to unlockit.co.nz to set data apn
Old 05-09-2014, 13:27   #148 (permalink)
Member: 2183028
Thanks Meter: 2
HelloI have an iPhone 5 locked on Vodafone uk. I unlocked it with rsim 9 pro.
Ios is 7.0.6
Problem is there is no setting to toggle 3G/4g I only have option to activate roaming...
I downloaded the irosetool and I only have 2g available. When I click force 3G signal drops and nothing happens...
I would like to know if there is a way to activate my 4g..... My operator supports it.....
The Following 2 Users Say Thank You to Hackfree For This Useful Post:
Old 05-10-2014, 05:28   #149 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,744
Ios is 7.0.6
no way right now , wait some time
The Following User Says Thank You to kinglock For This Useful Post:
Old 05-10-2014, 22:36   #150 (permalink)
Member: 2183973
is there a way to force 3G on ir0se tool please? cause i got only Edge and it's so fuuucking sloooow (((
Page generated in 0.18554 seconds with 9 queries
