How to use RSIM 10+ 1.input the unlocking sim card , the following menu will show , and please choose the operator http://www.rsim5.com/upload/attached...5025_45115.jpg [IMG]2.choose your unlocking mode[/IMG] [IMG]1)This mode can be compatible for most operators which can use 2G network[/IMG] http://www.rsim5.com/upload/attached...5329_17555.jpg 2)TMSI.2G3G4G There are two modes which can be chose when open this menu http://www.rsim5.com/upload/attached...5446_77140.jpg Use TMSI.2G3G4G , need to install free jailbreak or jailbreak version plug-in, ios9 free jailbreak one touch carrier patch. How to use the one touch carrier patch Download the software and install it. Insert the sim card and unlocking card into your phone and choose the right carrier. No matter the signal appears or not, just keep the phone as its desk mode, then click the option “about the device” to check the carrier. Connecting phone with computer, the “believe” option will jump out, please click it. After the patch realizes the phone, the version of phone will appear. Click “write in” the patch will be like non-working at one moment and at the same time, the computer need connect the internet. Log frame reminds ok now. That means the patch works now. Please check “about the device” again, if it is “China Unicom 21.1”, it success. Or restart your phone again and rewire in again until it is ok. Then you can handle the unlocking process of TMSI. 2.1 MI mode is voice reminding one, the usage as following http://www.rsim5.com/upload/attached...5550_59971.jpg This mode use for unlocking ios7.1-ios9, of course, it also can be used for unlocking other carriers to use 2G/3G/4G networks. But using TMSI unlocking mode under MI is not stable. If you use the TMSI, please plug out the card and insert it again to wait the signal coming. If no signal or internet, please ::: M2(iOS8-ios9)-》 http://www.rsim5.com/upload/attached...5646_90395.jpg [EMAIL="The unlocking steps of RSIM10+ (China mobile 4G, we suggest to update to ios9 system) First step: insert rsim and 4G sim card and select the carrier (now only support Sprint, AU, Softbank and DoCoMo to use 4G network), choose TMSI234G , click"]The unlocking steps of RSIM10+ (China mobile 4G, we suggest to update to ios9 system) First step: insert rsim and 4G sim card and select the carrier (now only support Sprint, AU, Softbank and DoCoMo to use 4G network), choose TMSI234G , click http://www.rsim5.com/upload/attached...5646_90395.jpg [IMG]then click “accept”, finish the setting up of the unlocking card Second step: plug the rsim, only insert the 4G sim card when the phone recognize the sim card, the “active mode” will jump out. At the same time, the 4G signal is solid. PS: this way also can be tried on China Unicom.[/IMG] The unlocking steps of RSIM10+ (China Unicom 4G, we suggest to update to ios9 system) F p: insert rsim and 4G sim card and select the carrier, choose TMSI234G , click http://www.rsim5.com/upload/attached...5646_90395.jpg then click “accept”, finish the setting up of the unlocking card Second step: the carrier patch is China Unicom 21.1, open the “setting up”, choose “cellular mobile network”, then “voice and data”, select 2G then can into “sim card application” , click http://www.rsim5.com/upload/attached...1129_81608.jpg [IMG]the phone will show “active mode” . The solid signal and E marks will flash. After that, the phone will return to the desktop. (If not, under solid E mark, press home key and emergency call *5005*7672*99#.) When see the solid E or outline E, into “voice and data”, click 3G, after 3G signal comes, please wait a moment. Click 4G, the signal will change into 4G. Switch on and off the flight mode. The 4G signal will change into a solid one. PS:This way also can be used to unlocking China Mobile CDMA 3G Card can use to unlock CDMA network, then can use the 3G SIM card. If install a source, also can use the CDMA card (suitable for ios 7.0-8.4)[/IMG] http://www.rsim5.com/upload/attached...0940_38075.jpg CDMA 4G Card(iOS8) unlocking CDMA 4G Card is suitable for ios8 http://www.rsim5.com/upload/attached...0949_95811.jpg [IMG]Ios9. CDMA 4G Card DMA 4G Card unlock ios9[/IMG] http://www.rsim5.com/upload/attached...1007_73311.jpg The unlocking steps of RSIM10+V8.1 (China Teleicom 3G/4G, we suggest to update to ios9 system) First step: insert rsim and sim card and select cdma4Gfor 4G card users, (now only Sprint, AU, Softbank s Second step: plug the rsim, only insert the cdma card when the phone recognize the sim card, the “active mode” will jump out. At the same time, the 3G signal is solid. (While the 4G card users will see the solid 4G) Click next, activate it, the phone will show the sim card is invalid. Off your phone again, wait more than 10 seconds when the screen is black. Third step: put the rsim and sim card into your phone together, power on, the signal will appear. http://www.rsim5.com/upload/attached...1045_37210.jpg [IMG]Select the unlocking mode,the chose mode will show an asterisk Edit IMSI code[/IMG] http://www.rsim5.com/upload/attached...1129_81608.jpg Restart SIM Card, can use for anti-activation. If there is no signal under TMSI mode,can click this option to get the signal. http://www.rsim5.com/upload/attached...1216_85726.jpg China Telecom 4G http://www.rsim5.com/upload/attached...1238_16300.jpg |
youtube link: https://www.youtube.com/watch?v=Cb4RRkLktCA |
rsim 10+ in iphone 5 sprint ios 7.1.1 sms and 2g internet not work what i do???????????????????????????:o:o:o:o:o:o:o:o:o |
support will delete your post soon :D they have no answer for some questions liars :) |
This team is idiots. Sorry but this is really. No support! No answer! Nothing.... iPhone 4s.iOS 9.2beta4 + Gevey using Tapatalk |
One stupid question I have is when it asks for the operator is that the one that it is locked to or is it what the new sim card is? |
Hmmm why delete my post? I have problem, but no support iPhone 4s.iOS 9.2beta4 + Gevey using Tapatalk |
https://www.youtube.com/watch?v=4ZnE...ture=********* iPhone 5s iOS 9.1 Rsim 10 unlock Sent from my iPhone using Tapatalk |
Work iPhone 5s locked Vodafone UK http://images.tapatalk-cdn.com/15/12...4344abd758.jpg http://images.tapatalk-cdn.com/15/12...84793c12a9.jpg http://images.tapatalk-cdn.com/15/12...852347b64b.jpg http://images.tapatalk-cdn.com/15/12...a3d8819bb9.jpg iPhone 4s.iOS 9.2beta4 + Gevey using Tapatalk |
suport sim LTE???? post settings please |
Sorry but in my country don't have LTE network about test. iPhone 4s.iOS 9.2beta4 + Gevey using Tapatalk |
Trying with iphone 5C Bell ios 8.3 but NOT work. Should I upgrade to iOs 9.1? BR |
Well, I just upgraded the iPhone 5S to 9.1 and it's NOT working still. Anyone can help me here? I'm been using this Sim interposers since the first gevey for iphone 4 and I think after the Rsim pro all have been out from Rsim it' pure Crap.... |
