07-21-2020, 12:27 | #1 (permalink) |
Junior Member Join Date: Oct 2019 Location: Spain
Member: 2934440 Status: Offline Thanks Meter: 0 | Not menu popping I cannot reach the Menu to try to change the ICCD ( i guess it's supossed to pop up automatically but it's not working ),neither i can reach the Settings of Iphone to change it manually. ( I'm stuck in the Not valid Sim card ) ( I'm not new user i was trying to change ICCID since yesterday my Phone rebooted and stop working properly,im trying to update the ICCID. (*5005*7xxxxxxx) dsnt work neither I tryed reseting red aspecs ( I'm using RSIM15 ) |
07-21-2020, 13:23 | #2 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2820889 Status: Offline Thanks Meter: 14 | Take sim out and insert sim(original carrier) and rsim you will then be able to go to settings-cellular-sim applications from there choose appropriate function. First "edit iccid" then use "iccid mode" after you edit the iccid. And done it will have updated iccid and also the correct mode for you to unlock. Sent from my SM-N975U using Tapatalk |
The Following User Says Thank You to Reack For This Useful Post: |
07-21-2020, 14:51 | #4 (permalink) |
Member: 2934440 Status: Offline Thanks Meter: 0 | Hey,thanks very much for your reply ! I did try to remove the Rsim + SIM and insert only SIM,then Remove Sim and insert back Rsim + SIM and still happening Hope this is what you mean? Oh nvm,what about if i dont have the Original carrier SIM anymore? Last edited by hehe666; 07-21-2020 at 14:58. |
07-21-2020, 15:10 | #6 (permalink) |
Member: 2820889 Status: Offline Thanks Meter: 14 | Any sim from original carrier will work. Needs to be original carrier sim does not need to be unique to the phone. Both rsim15 and that sim needs to be in. Example sprint phone unlock to att. Insert sprint sim not activated is fine. Go thru sim applications. There is instructions on this site that is more detailed with video i believe. Just try that search bar and bam you'll see it. Sent from my SM-N975U using Tapatalk |
07-21-2020, 15:16 | #9 (permalink) |
Member: 2820889 Status: Offline Thanks Meter: 14 | Try to insert the sim you do have and rsim in a factory unlocked phone. I think that still works. Or use any carrier to see of you can get the menu to pop up. If not maybe its defective. Try another rsim Sent from my SM-N975U using Tapatalk |
