Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-30-2014, 12:41   #586 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
Originally Posted by giovastrova View Post
Hi first of all, i do not work for rsim! The reason of my post is just to guide you through so you can set up this ****! i say this **** because setting up this card has been one of the worst nightmares ever but i finally made it. I dont have any pics, Reason why is because i sold the phone( MONEY TALKS)! but ill guide you through it. Im from El Salvador Central America and i tested it with a TIGO Nano Sim card. (Dont know what tipe of sim) WITH A IPHONE 5 AND WITH A RSIM AIR 2
I CANNOT POST LINKS BECAUSE ITS MY FIRST POST, SO I CANT POST PICTURES.
STEPS!!
0) MAKE A FRESH INSTALL OF YOUR IOS. (RESTORE IPHONE)
1) Insert Rsim along with the Sim you want to activate.
a)Then select US SPRINT
b) After it select Iphone5/5c/5s
c) **IMPORTANT** Instead of selecting IOS 7.1/7.X YOU HAVE TO SELECT IOS 7.0! Even though your ios is 7.1.1 or 7.1.2 (This will avoid the activation screen to keep coming)
d) Restart your phone.
e) After restarting, the phone will start searching. If its not working dont worry we will fix it in a bit.
Optional: You can test the network by going to settings->Carrier> and Deselecting "Automatic selection" When you see the spining wheel loading the list, go back and put your iphone in airplane mode for a few seconds. Remove the airplane mode and wait a few minutes. You should now see your network active. If this doesnt work dont worry, on the next steps we will fix it.
2) The second step is to jailbreak your Iphone with Pangu. You can download it at pangu[dot]io
3) Using Cydia go to sources->Edit->Add-> www[dot]isamteam[com]
4) Tap the isamteam repo, and select the third option just below "All packages". It will say R-SIM and on the left side it will have the number 1.
Now select the following file "A:RSIM iOS 7 5s/5c/5" and install it. MAKE SURE THAT IT SAYS A: before the name.
- Then Restart your phone.
This step will install the patch, so the phone can look for the network, and will give you Edge and SMS.
5) Now go to settings -> Cellular and Activate everything except CDMA INTERNATIONAL.
(IF YOU DONT GET EDGE DONT WORRY WE WILL FIX IT ON THE NEXT STEP)
6) Finally so you can get the 2g or 3g you need to install Irosetool.
a) On your phone Go to unlockpro[dot]ru/nano4g. Tap on install
After installing Irosetool restart your phone.
7) Go to irosetool and tap on Force 2g first and then Tap on force 3g.
The main reason of Rsim not working is:
1)On the Rsim setup DONT SELECT ios 7.1./7.X, INSTEAD SELECT 7.0
2)INSTALLING THE INCORRECT PATCH, PLEASE INSTALL THE PATCH THAT HAS THE LETTER A: AT THE BEGINING.
This walthrough has been tested on a Sprint Iphone 5 with a RSIM AIR 2
Give me some feedback to see if it Works. Good luck guys!
Thanks for this guide!! But i'm not sure if it will work on a Sprint 5S
Old 07-30-2014, 16:22   #587 (permalink)
Member: 2208296
Hi.
I hope youo guys can help me!
i have a 4S Sprint iOS 7.1.2. But I CAN'T unlock my fone at all!! Even calls, its cant estabize!!
I try 2 rsim air 2 diferent, but always loop on "SIM NOT VALID" messagem,
1 - SIM not valid
2 - Signal
3 - Phones reboot!
This is an infinite loop, I let my phone 10 hours, and this loop goibg on , and on , and on!!
What chip I should to use? What's steps?
This is a brend new phone, and I can't use it =(
Old 07-30-2014, 17:23   #588 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
Originally Posted by zumba_rox View Post
Hi.
1 - SIM not valid
2 - Signal
3 - Phones reboot!
Hi for the iPhone 4S is better to use the R-Sim 9 pro because it works perfect with no activation issues on the iPhone 4S!
You can try R-Sim 9 or GPP and you will have no issues, R-Sim Air 2 is just for Sprint 5S/5C
Old 07-30-2014, 20:00   #589 (permalink)
Member: 2208296
Hi, iven SPRINT carrier? My iPhone it's Sprint, with iOS 7.1.2
Old 07-30-2014, 20:02   #590 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
Yes, for any iPhone 4S is better the R-Sim 9 because R-Sim Air 2 is only for 5s models
Old 07-31-2014, 06:54   #591 (permalink)
Member: 2231916
Thanks Meter: 2
Hi guys, it's my first post on the forum
I'd like to ask, if my iPhone has been restored (fresh iOS as you wrote), is it required to activate the handset using Sprint sim or just put in the R-SIM Air 2 with the sim wanted to activate and it should works?
Thx!
Old 07-31-2014, 13:23   #592 (permalink)
Member: 2217992
7.12 work fine as same as 7.11
Old 08-01-2014, 09:36   #593 (permalink)
Member: 137809
you re saying it works fine for u, can u pls post procedures here so others can follow up what u did to make it work......
Old 08-01-2014, 12:46   #594 (permalink)
Member: 2231916
Thanks Meter: 2
As said, could somebody please post full procedure, how to activate it correctly to make it working properly?
Many thanks
Old 08-01-2014, 15:16   #595 (permalink)
Member: 2232682
This question is designed to support team of the manufacturer.
Through so many products and many issues related to the products, I wonder if the new chip r-Yes9 + cloud is higher than AIR2, it contains all the codes of the AIR2? Because I have an iphone 5c CDMA which is asking activation constantly, and would whether the new chip solves this problem and makes it work correctly 5C sprint CDMA iPhone.
Note: MINI2 recently tested the new version with the 9.8 and it does not come out of the activation screen.
I await RESPONSE thanks.
Old 08-04-2014, 15:22   #596 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
9+ is optimized based on feedbacks we got on R-SIM mini2 ,air2,
Old 08-04-2014, 19:02   #597 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
But does it work on Sprint 5s and 5C without problems?
Old 08-05-2014, 14:18   #598 (permalink)
Member: 2231916
Thanks Meter: 2
I'm using R-SIM AIR 2 with iPhone 5S locked by Sprint USA with Play sim card in Poland. Everything's rather ok:
Incoming/Outgoing calls: OK
Incoming/Outgoing SMS: OK
Incoming/Outgoing MMS: NOT CHECKED YET
Internet: Only EDGE, needs R-Patch
Internal roaming Works with other networks properly
But I have a problem with range, I'm living in the place where's hard to catch a range and when handset shows Searching..., the iPhone still wants to activate the iPhone, it makes me mad
When it has been restored, it was activated by R-SIM AIR 2, maybe somebody know, what causes this problem and know, how to solve it?
Many thanks for help!
Old 08-06-2014, 07:03   #599 (permalink)
Member: 686260
Can someone please point me in the best direction to purchase R-Sim Air2 from please?
Old 08-06-2014, 12:19   #600 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
iPhone unlock card iPhone R-SIM9 8 7 Air Mini Pro unlock Unlock iPhone rsim Unlock for iPhone expert RSIM 9 PRO mini air,R-SIM8+,SAMSIM,3G,R-SIM5+,R-SIM6,RSIM5+,RSIM6,RSIM7,R-SIM7+?Unlock,iPhone5,iPhone4S,Firmware,Any version, No jailbreak
Page generated in 0.25614 seconds with 11 queries
