07-30-2014, 12:41 | #586 (permalink) | |
Temporary banned !! Join Date: Feb 2014
Member: 2127068 Status: Offline Thanks Meter: 51 | Quote:
Thanks for this guide!! But i'm not sure if it will work on a Sprint 5S | |
07-30-2014, 16:22 | #587 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2208296 Status: Offline Thanks Meter: 0 | Hi. I hope youo guys can help me! i have a 4S Sprint iOS 7.1.2. But I CAN'T unlock my fone at all!! Even calls, its cant estabize!! I try 2 rsim air 2 diferent, but always loop on "SIM NOT VALID" messagem, 1 - SIM not valid 2 - Signal 3 - Phones reboot! This is an infinite loop, I let my phone 10 hours, and this loop goibg on , and on , and on!! What chip I should to use? What's steps? This is a brend new phone, and I can't use it =( |
07-30-2014, 17:23 | #588 (permalink) | |
Hi for the iPhone 4S is better to use the R-Sim 9 pro because it works perfect with no activation issues on the iPhone 4S! You can try R-Sim 9 or GPP and you will have no issues, R-Sim Air 2 is just for Sprint 5S/5C | |
07-31-2014, 06:54 | #591 (permalink) | |
Junior Member Join Date: Jul 2014 Location: Warsaw / Poland
Member: 2231916 Status: Offline Thanks Meter: 2 | Quote:
I'd like to ask, if my iPhone has been restored (fresh iOS as you wrote), is it required to activate the handset using Sprint sim or just put in the R-SIM Air 2 with the sim wanted to activate and it should works? Thx! | |
08-01-2014, 15:16 | #595 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2232682 Status: Offline Thanks Meter: 0 | This question is designed to support team of the manufacturer. Through so many products and many issues related to the products, I wonder if the new chip r-Yes9 + cloud is higher than AIR2, it contains all the codes of the AIR2? Because I have an iphone 5c CDMA which is asking activation constantly, and would whether the new chip solves this problem and makes it work correctly 5C sprint CDMA iPhone. Note: MINI2 recently tested the new version with the 9.8 and it does not come out of the activation screen. I await RESPONSE thanks. |
08-05-2014, 14:18 | #598 (permalink) |
Member: 2231916 Status: Offline Thanks Meter: 2 | I'm using R-SIM AIR 2 with iPhone 5S locked by Sprint USA with Play sim card in Poland. Everything's rather ok: Incoming/Outgoing calls: OK Incoming/Outgoing SMS: OK Incoming/Outgoing MMS: NOT CHECKED YET Internet: Only EDGE, needs R-Patch Internal roaming Works with other networks properly But I have a problem with range, I'm living in the place where's hard to catch a range and when handset shows Searching..., the iPhone still wants to activate the iPhone, it makes me mad When it has been restored, it was activated by R-SIM AIR 2, maybe somebody know, what causes this problem and know, how to solve it? Many thanks for help! |
