09-28-2013, 20:29 | #1 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1790034 Status: Offline Thanks Meter: 8 | Discussion : ios Activation Via R sim ?! hi every Body now No bypass for ios 7 activation tell this moment ! im talking for the final ios 7 any body try to activation via Onesime Or Rsim ( using original carrier code ) thanks for sharing ur experience With us |
09-28-2013, 20:48 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Did you try to use head for thinking? Apple blocked activation on the server side, not in iPhone. How you can force server to do something via R-sim? |
The Following User Says Thank You to ribbentrop For This Useful Post: |
09-28-2013, 21:08 | #3 (permalink) | |
Member: 1790034 Status: Offline Thanks Meter: 8 | Quote:
im talking about activation ( when iphone ASk about original sim to activate it ) | |
09-28-2013, 23:20 | #5 (permalink) | |
on Beta version it was this bypass : How to Bypass iOS 7 Activation Screen iPhone 5/4S/4 7.0 - YouTube but in the final ios 7 it not work any more . | |
09-29-2013, 11:20 | #7 (permalink) |
Freak Poster Join Date: Nov 2010 Location: morocco
Member: 1433316 Status: Offline Sonork: 1663603 Thanks Meter: 23 | yes you can activate it .use redsnow redsn0w_win_0.9.15b3 and select extras after select ipsw shows iPhone3,1_6.0_10A403_Restore .after click back and do jailbreak .wait when jailbreak is finish .complet setup for activation .note dis jailbreak just only for iphone 4 |
The Following User Says Thank You to taoufik+1 For This Useful Post: |
09-29-2013, 14:18 | #8 (permalink) |
Freak Poster Join Date: Oct 2009 Location: HEART OF !ND!A. JABALPUR Age: 30
Member: 1150164 Status: Offline Sonork: 100.1593001 Thanks Meter: 55 | pls guide me step by step.. how to jailbreak and etc for pass activation.. pls give me link or tutorial i dnt want to ruin my fone.. pls |
09-30-2013, 01:12 | #11 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Bangkok Thailand
Member: 830167 Status: Offline Thanks Meter: 82 | Of cause, I'm used R-SIM to pass the activation process with no problem even currently iOS 7.0.2. But after iOS 7 released I can only use R-SIM 8, 8 Gold and 8+ for activation. But the trick is, You have to setting the correct R-SIM's imsi as the Phone locked to and also waiting for the phone recognize the SIM and get the signal bar (if possible). After that you will pass the activation process like a you have the original SIM on its. |
09-30-2013, 01:13 | #12 (permalink) |
Member: 1449117 Status: Offline Thanks Meter: 35 | Steps to take to activate without original SIM 1. Install R-SIM 8 with ACTIVE SIM 2. MENU will pop up, CHOOSE i5 and ORIGINAL CARRIER 3. Three beeps, and Successful Message will pop up. 4. Reboot iphone 5. Before going to activation screen, wait till you have a signal bars or no service 6. Go to activation screen and it will allow you to bypass it. NOTE:: You NEED an active sim card, and also you won't get the MENU if the R-SIM is already programmed with the CHIP. In this case, use A DIFFERENT SIM so that the MENU pops up again! |
The Following 3 Users Say Thank You to Alimaxor For This Useful Post: |
09-30-2013, 07:34 | #13 (permalink) | |
Insane Poster Join Date: Dec 2009 Location: where people love each other
Member: 1185485 Status: Offline Thanks Meter: 8 | Quote:
For best use, use un-cut nano sime! it works every time for me..! thats the reason I have got new nano sim with my same number | |
