Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 09-19-2014, 09:14   #1 (permalink)
Member: 1895099
Sonork: 100.1647265
Thanks Meter: 148
Iphone 5C Sprint USA Unlocking Problom Plzz Help
I hava Iphone 5C which is locked to Sprint USA and IOS version is 7.0.1 and
am try with rsim 9 Pro And Also try with Rsim 9 Gold . When We insert the sim
and select the carrier and then restart the iphone it says activation required
Am in Big trouble plzz help
Old 09-19-2014, 10:14   #2 (permalink)
Member: 2117665
Thanks Meter: 39
You need to update you phone to IOS 7.1.2 to get it unlock through R Sim, as any R Sim Version is not able to unlock i5S/5C Sprint on 7.0.4 or lower.
R Sim 9Pro and 9 Gold will not work on 7.1.2, you have to use R Sim Mini V9.8 or R Sim Air2. But i think you are too late to update you phone on 7.1.2 as Apple might stop singing 7.1.2 because IOS 8 is already out.
Old 09-19-2014, 10:37   #3 (permalink)
Member: 1895099
Sonork: 100.1647265
Thanks Meter: 148
is there any solution for it?
Old 09-19-2014, 10:59   #4 (permalink)
Member: 2117665
Thanks Meter: 39
You need to wait for the R Sim Team to confirm that it will work on IOS 8 or they will launch new R Sim for IOS 8..
Old 09-19-2014, 12:37   #5 (permalink)
Member: 1895099
Sonork: 100.1647265
Thanks Meter: 148
i think you right and my problom is not solve
Old 09-19-2014, 16:38   #6 (permalink)
eduard504's Avatar
Member: 2124335
Sonork: 1652594:eduard504
Thanks Meter: 83
buy a r sim mini 2 v10.1, works for me with 5s sprint iphone ios 7.1.2
Old 09-19-2014, 19:40   #7 (permalink)
Member: 2033138
Thanks Meter: 17
Best is to get it factory unlocked through Worldwide service as its up now or update the phone to ios 8 now and would be able to call, no data no msg...until jailbreak arrives.
Old 09-19-2014, 20:50   #8 (permalink)
eduard504's Avatar
Member: 2124335
Thanks Meter: 83
the problem of factory unlocked, is not sure that the phone be locked again,
Old 09-20-2014, 08:02   #9 (permalink)
Member: 1895099
Sonork: 100.1647265
Thanks Meter: 148
am tried to factory unlock but service not work
Old 09-20-2014, 08:25   #10 (permalink)
Member: 2117665
Thanks Meter: 39
Just update you iPhone to 7.1.2, apple still singing this version. Use R sim Mini 2 V9.8 to unlock and for Internet & SMS Jailbreak it through Pangu and install Patch A from isamteam.com repo through cydia.
You will not get Incoming Call/SMS while on 3G Mode, but will works perfectly on Edge mode.
Old 09-20-2014, 18:55   #11 (permalink)
Crazy Poster
Member: 1651343
Thanks Meter: 4
here's all the 7.1,2 firmware for all apple devices to upgrade wwwredmondpiecom/download-ios-7.1.2-for-iphone-ipad-direct-download-links/ just add the dots
Old 09-22-2014, 08:17   #12 (permalink)
007vivek007's Avatar
Member: 2146521
Sonork: 100.1654013
Thanks Meter: 36
Red face
I'm getting a huge distortion on calls when installing PATCH A from Cydia always. The function of Patch A: is to just replace Sprint bundle with CarrierLab.bundle. You can confirm it by navigating to the sprint bundle and then can open the carrier.plist. You will see carrier name as "Carrier Lab".
IT'S THE SAME ****
Call distortion sometimes reduced when you lost E/3G OR while in a different state.
FED UP THIS ****ING R-SIM.
Old 09-23-2014, 11:20   #13 (permalink)
Member: 2257877
i want to unlock my iphone 5c sprint usa is that possible??
Old 09-23-2014, 11:25   #14 (permalink)
Member: 2262536
yes, possible. can use newest R-Sim or Gevey
Old 09-23-2014, 19:48   #15 (permalink)
Member: 2033138
Thanks Meter: 17
Best is to get it factory unlocked and then save the activation tickets so that if in case it gets locked you would be having the tickets saved and can be put again to that location to unlock the phone again but jailbreak needed for this task!
Page generated in 0.23025 seconds with 9 queries
