01-27-2014, 13:19 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2112599 Status: Offline Thanks Meter: 4 | iPhone 5 Sprint 9 Pro - no menu again problems with Sprint phones: this time a normal ip5. RSim works on 5C but not on that ip5 have no other to test. I set up with Sprint SIM and then tried RSim also tried completely with RSim, reset phone - nothing work the black menu does not pop up. Device has iOS 7.0.4 |
01-30-2014, 04:03 | #4 (permalink) | |
Member: 2117315 Status: Offline Thanks Meter: 0 | Quote:
can you tell me how to update sim application from 9 Pro ? | |
01-30-2014, 04:35 | #5 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | Probably they were part of the patch with the outdated sim application , now the question is can you update the sim application on the 9 pro the answer would be no since it was a faulty chip and because of this they came out with the updated 9pro , when it comes to the warranty option in my opinion if you buy something and it does not work then yes you got to contact your seller to honor of the two either an exchange or a full refund. |
01-30-2014, 18:36 | #6 (permalink) |
Member: 2112139 Status: Offline Thanks Meter: 0 | Iphone 5 Sprint iOS 7.0.4 no menu Hello I'm also having a this problem but my phone is not a CDMA model. It's an iphone 5 A1429, Sprint locked. When I use the r sim with a local nano sim no menu comes up. I tried using another sim and even another iphone 5. Why is there no menu coming up? Is it possible that the chip got damaged in the post? |
