Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 03-20-2020, 20:36   #16 (permalink)
Member: 2796343
Sonork: K_A_K_I
Thanks Meter: 2
Hello, please add video
The Following User Says Thank You to K_A_K_I For This Useful Post:
Old 03-21-2020, 20:22   #17 (permalink)
Member: 2751138
Pls can’t I used windows laptops to do? Or only mic book?thanks
Sent from my iPhone using Tapatalk
Old 03-26-2020, 08:09   #18 (permalink)
Member: 2796343
Sonork: K_A_K_I
Thanks Meter: 2
NO MY FRIEND I MEAN FULL VIDEO FOR IPHONE 5s AND IPHONE 6
Old 03-28-2020, 17:18   #19 (permalink)
Member: 2793567
Thanks Meter: 6
Originally Posted by kinglock View Post
Activation by ICCID iPhone 6, 6+ and 5s:
2. Thanks to the Apple File Conduit “2” tweak installed earlier, we connect the phone to any program (iTools, 3Utools, etc.) and go to the “File System” section.
3. In 3Utools, as an example, we go along the path System / Libraries / Coreservices. Delete the SystemVersion.plist file and rename the previously copied source file named SystemVersion (1) .plist to SystemVersion.plist. That is, without "(1)".
4. We reboot the device with the buttons. The download will be long, with a running status bar.
Dear Kinglock, pardon my noobness but could you please help - as at this step I am not able to install or user filza, 3utools etc to update the plist.
Is 3utools to be used via PC or mac?
Except cydia all app like filza etc are crashing.
Please advise - thanks in advance
Old 04-07-2020, 00:03   #20 (permalink)
Member: 2274427
Thanks Meter: 23
1.We take the phone, put the jail checkrain 0.9.8.2.
2. We go into the side and put Filza File Manager and Apple File Conduit “2”
3. Through Filza we go along the path System / Libraries / Coreservices. Copy the SystemVersion.plist file to the same folder. The file will be called SystemVersion (1) .plist
4. Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion to 17D50. Then we return and in ProductVersion we change the value to 13.3.1. Click save and done.
5. We reboot the device with the buttons. The download will be long, with a running status bar.
6. After loading the device, insert the sandwich and enter the current ICCID in the drop-down menu.
7. We go through the activation and we have a fully functioning device. (will not work without a gasket)
Now return the firmware version:
1. We take the phone, again we put the jail checkrain 0.9.8.2.
That's all. The phone remains on the old firmware 12.4.x and works as a non-wizard. After all the manipulations, all applications work stably, both old and just installed.
done work 100% tested
Old 04-10-2020, 16:51   #21 (permalink)
Member: 1837220
Thanks Meter: 20
unlock iccid iphone 5, 6 6plus with working app
https://www.youtube.com/watch?v=dKJ1yovyyAo&t=7s
Old 04-11-2020, 14:13   #22 (permalink)
Member: 2793567
Thanks Meter: 6
Originally Posted by ablmix View Post
excellent video thanks you very much - i have done on checkr1n 0.10.1 beta
Old 04-26-2020, 16:05   #23 (permalink)
Member: 1163064
Sonork: zyril
Thanks Meter: 6
apps not working after respring sir any solution?
Old 04-27-2020, 17:58   #24 (permalink)
Member: 1015560
Thanks Meter: 2
Applications not work iphone 6 last version?
Old 05-07-2020, 19:03   #25 (permalink)
Member: 1889273
Thanks Meter: 12
WHAT ABOUT iphones 4S ?????
Old 05-09-2020, 04:13   #26 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,693
1. Jailbreak para instalar Cydia.
2. instala Filza
3. Ve Filza - System - Library - CoreServices - file SystemVersion.plist
4. Edit SystemVersion.plist
- Version iOS : 13.4.1
- Buildversion : 17E262
5. Reinicia el equipo , y activa el ICCID con el chip que va quedar
6. Dirigete a iTunes Shift + Update(actualizar )y seleccionas el firmware mas Nuevoo para tu iPhone ( iPhone 6 o 6 Plus)
7. Done.
Nota : Te recomiendo quitar codigo desbloqueo !
Old 05-09-2020, 16:20   #27 (permalink)
Member: 1889273
Thanks Meter: 12
2. instala Filza
7. Done.
iphone 4s 可以吗????????????????
Old 05-15-2020, 02:40   #28 (permalink)
Member: 1647504
Thanks Meter: 236
video auto fake IOS
https://www.youtube.com/watch?v=FJF3eXacInQ
Old 06-29-2020, 05:13   #29 (permalink)
Member: 1907775
Thanks Meter: 2,693
https://www.youtube.com/watch?v=fUdG...ture=*********
Old 06-29-2020, 05:22   #30 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 67
still no service on ip5s
The Following User Says Thank You to dre2 For This Useful Post:
Page generated in 0.24378 seconds with 8 queries
