08-24-2014, 17:36 | #91 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2224107 Status: Offline Thanks Meter: 0 | I've installed the patch and click on the 3g#### in the menu, but I've always had the message " Your phone played a tone" and then no signal after this.. What can I do? thx |
09-04-2014, 15:52 | #94 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1291202 Status: Offline Thanks Meter: 4 | have iPhone 5c sprint unlocked using rsim air 2 v10 , 3G works, SMS not working , another problem is when I move between states iphone signal move to fake signal with blank dots , then I have to press 3G under sim applications and reboot again , then it works again . Any way I can fix SMS and this issue ?? |
09-15-2014, 00:43 | #96 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2165190 Status: Offline Thanks Meter: 8 | STEPS I USED TO UNLOCK IPHONE 5S SPRINT IOS 7.1.2 RSIM MINI 2 V10.1 - install new IOS (7.1.2) - (turn on cellular data), turn off enable 3g, turn off data roaming - insert rsim + sim card - select the last option of the rsim menu - select us sprint - accept and reboot - when phone powers on make sure you have empty dots with your carrier name displayed - jailbreak iphone with Pangu - ADD: isamteam.com and install - install patch A A1 and M - go to sim aplication and click on GSM mode (IOS7.1.x) you should see *GSM - then click on 3G with chinese writing - you would see one black dot on the carrier bar - wait for some minutes \ - you still have to have one dot with beside your carrier name rsim would ask you to reboot - cancel turn phone off and turn back on hope this works for you because i used this method to unlock iphone 5s sprint 5c sprint 5c tmobile with 32 and 64k card only.... would be posting videos soon |
10-24-2014, 19:07 | #102 (permalink) |
Junior Member Join Date: Jun 2008
Member: 797781 Status: Offline Thanks Meter: 0 | Iphone 5 locked on optimus portugal, with vodafone 256k sim doesn't get signal with mini 2 v10.1 in 3g mode. It works only with irose tool in 2g mode (ios 7.1.2, 8). Maybe after 2 or 3 years we will have 3g/4g working on our iphones.... |
