GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 07-21-2020, 12:27   #1 (permalink)
Member: 2934440
Not menu popping
Doubd:
I cannot reach the Menu to try to change the ICCD ( i guess it's supossed to pop up automatically but it's not working ),neither i can reach the Settings of Iphone to change it manually. ( I'm stuck in the Not valid Sim card ) ( I'm not new user i was trying to change ICCID since yesterday my Phone rebooted and stop working properly,im trying to update the ICCID.
(*5005*7xxxxxxx) dsnt work neither
I tryed reseting red aspecs ( I'm using RSIM15 )
Old 07-21-2020, 13:23   #2 (permalink)
Member: 2820889
Thanks Meter: 14
Take sim out and insert sim(original carrier) and rsim you will then be able to go to settings-cellular-sim applications from there choose appropriate function. First "edit iccid" then use "iccid mode" after you edit the iccid. And done it will have updated iccid and also the correct mode for you to unlock.
Sent from my SM-N975U using Tapatalk
The Following User Says Thank You to Reack For This Useful Post:
Old 07-21-2020, 13:24   #3 (permalink)
Member: 2820889
Thanks Meter: 14
Oh sorry take out sim (original carrier) then unlock.
Old 07-21-2020, 14:51   #4 (permalink)
Member: 2934440
Hey,thanks very much for your reply !
I did try to remove the Rsim + SIM and insert only SIM,then Remove Sim and insert back Rsim + SIM and still happening
Hope this is what you mean?
Oh nvm,what about if i dont have the Original carrier SIM anymore?
Old 07-21-2020, 15:02   #5 (permalink)
Member: 2934440
x2 tryed to edit by msitake
Old 07-21-2020, 15:10   #6 (permalink)
Member: 2820889
Thanks Meter: 14
Any sim from original carrier will work. Needs to be original carrier sim does not need to be unique to the phone. Both rsim15 and that sim needs to be in.
Example sprint phone unlock to att.
Insert sprint sim not activated is fine. Go thru sim applications. There is instructions on this site that is more detailed with video i believe. Just try that search bar and bam you'll see it.
Old 07-21-2020, 15:11   #7 (permalink)
Member: 2820889
Thanks Meter: 14
Insert both sim and rsim. Each time dont just use sim only.
Old 07-21-2020, 15:14   #8 (permalink)
Member: 2934440
Which i wasnt able to edit last time is that the Original Carrier Sim is something that i dont have with me there is any other solution ?
Old 07-21-2020, 15:16   #9 (permalink)
Member: 2820889
Thanks Meter: 14
Try to insert the sim you do have and rsim in a factory unlocked phone. I think that still works. Or use any carrier to see of you can get the menu to pop up. If not maybe its defective. Try another rsim
Old 07-22-2020, 10:34   #10 (permalink)
Member: 2934440
ty ty solved ussing other card and it automatically pop,thanks very much !
Page generated in 0.37093 seconds with 7 queries
