Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-14-2017, 13:47   #31 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,693
Originally Posted by mak102 View Post
I am trying to use my iPhone 6 (locked to vergin) with t-mobile SIM but everytime I insert sim with r-sim 11+ it does not recognise the sim - on top left corner it says No SIM. Can you please provice any solution?
Thanks.
it may broken if always No SIM , unlock menu code : *5005*7672*0#
Old 07-16-2017, 03:36   #32 (permalink)
Member: 2297287
Thanks Meter: 7
Hi i have 2 rsim 11+ that in the first attemp to unlock a iphone 5s, show invalid sim. I TEST the rsim in a iphone 5s unlocked and show ´error sim` and show in the signal bar, invalid sim. When i go to setting of rsim, show sim application and the option but i cant re configurate and no pop the menu. i mean, i click any option, select carrier, unlock 1, lock carrier, etc but nothing happen. any help
Old 07-17-2017, 04:58   #33 (permalink)
Member: 1907775
Thanks Meter: 2,693
RSIM111+ is auto ,no need setting , just waiting and Reboot Phone
if not , select the locked carrier iphone 5s
Old 07-18-2017, 03:36   #34 (permalink)
Member: 2297287
Thanks Meter: 7
Thanks friends but repeat, I inserted the Rsim and show me the message "error sim" then in the signal bar in the upside in the left show "invalid sim". This test is in a unlocked iphone later that show invalid sim in a locked iPhone 5s.
Repeat, the Rsim show the menu of Rsim but if select any option, nothing happen. I mean, the menu is freeze. No pop menu. I can't select locked carrier or any option. Please help
Old 07-22-2017, 12:29   #35 (permalink)
Member: 2739394
it works on ios 10.3.3?
Old 07-26-2017, 21:57   #36 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 363
iPhone 5S Tracfone calls are ok but no data "Data Roaming is turned off ..." even with roaming enabled, installing 10.3.3 would make any diference?
Network - Claro
Version - 9.3.3 (13G34)
Carrier - KDDI 24.2
Old 07-27-2017, 06:58   #37 (permalink)
Member: 1247453
Thanks Meter: 13
Perfect ---- R-SIM11 plus for All ios Stable LTE 4G ,
Real plug and play ,
Where to buy? I want R-sim11+ Plus
Old 07-27-2017, 11:41   #38 (permalink)
badi's Avatar
Member: 11945
Thanks Meter: 76
hello
anyone here have the r-sim hardware modification to solder the R-sim inside iphone?
to be like an factory unlock phone.
Old 07-27-2017, 11:44   #39 (permalink)
Member: 2741164
I have EXACLY the same problem. Any news?
Old 07-28-2017, 23:47   #40 (permalink)
Member: 2297287
Thanks Meter: 7
No news. I'm waiting for any answer for the experts of this forum. I hope that kinglock or any, tells a solution.
Old 08-08-2017, 15:59   #41 (permalink)
Member: 2297287
Thanks Meter: 7
I have many weeks wait any help for many case in rsim 11+ with error sim mesagge (invalida sim in signal bar). When i put a 128k chip in a iphone 6 for example, this show a message error sim and invalid sim in signal bar, then i cant use anymore this rsim because no reponse in any iphone or any chip. In the rsim menu (setting/Phone/Sim application) show marked *GSM MODE/2/3/4G Card, CDMA 4G Card, I5s-I7, LTE 4G and Lock Carrier and dont let me change the rsim configuration.
HOW CAN I DO IN THIS CASES, I HAVE MANY RSIM IN THIS CONDITION
Old 08-15-2017, 22:51   #42 (permalink)
Member: 2394050
Thanks Meter: 47
this rsim works in IOS 10.3.3 ??
Old 09-12-2017, 09:17   #43 (permalink)
Member: 2756888
Works on My Iphone 6S IOS 10.3.3 locked to A1-Austria
Plug and play after reboot other Sim Working
Old 09-25-2017, 20:02   #44 (permalink)
Member: 2049377
Iphone 6 and 6 plus working with R-Sim 11 plus 10.3.3 on 3G
I haven't tried using a 4G sim card yet, will it work?
Can I update to iOS 11?
Was locked to boost mobile/sprint, but now works fine for 3G.
Old 09-26-2017, 03:51   #45 (permalink)
Member: 1907775
Thanks Meter: 2,693
its ok for a 4G sim card , do not worry .
Page generated in 0.28898 seconds with 8 queries
