R-SIM AIR, iPhone 4S, no 3G... Please help! Hello team, I've recently purchased a R-SIM AIR. I've checked its authenticity and it went ok. I've replaced my original SIM for this one along with the provider's SIM I want to use and it worked fine. But I only got Edge network. I thought it could be related with LTE patch so I purchased an activation code and I was able to apply the code successfully. But still no 3G... Not even the option under settings>cellular. So I upgraded to 7.1.2 (was 7.0.1) and still no 3G... Now, I also have a new message, I had never seen before when I try to setup the hotspot ("To enable personal hotspot on this account, contact Vodafone P") I did install a specific profile for APN for this operator, I obtained it from unlockit. co. nz Original network: Vodafone Portugal Current network: Tesco Mobile (they are a MVNO) Can this be related to the fact that I don't have my phone jailbroken? Please advise, Thanks, LM |
Hi friend,i'm steve from RSIM team. If you want to solve iphone4s 3G problem,you need rsim air and jailbreak,then add the:www.isamteam.com rsim repo and istall the C&D patch. |
Hello Steve, thanks for the suggestion. I've did your recommendation, but the patch didn't do the work, or maybe I've installed the wrong patch? I've installed A1:CommCenter patch and C:R-SIM iOS 7/6 4S Please advise if I should remove those and install another. 3G is still not working... :( Thank you! |
IT Finally worked!!! I'm posting the steps, as someone else may need it! All I needed was to change the R-sim mode to "Mode 2 (iOS6) M2 3G" The title of the option was misleading, as it worked and I'm running 7.1.2 (I don't know, though, if the isamteam patch from Cydia is needed or not, as I had it already installed from previous attempts) Thank you, and keep up the good work, this forum rocks! |
