03-11-2020, 22:38 | #16 (permalink) |
Insane Poster Join Date: Jun 2014 Location: iran
Member: 2213455 Status: Offline Thanks Meter: 17 | But 2 questions 1 update 19.3 or 16.2 ?? Im chk support cant find 19.3. Only 16.1 and 16.2 new 2. I have tracfone lock. On r sim no tracfone and update rsim to 16.2 must select operator and select iccid unlock with 16.2 no tracfone and only iccid mode activation |
03-12-2020, 00:11 | #19 (permalink) |
Freak Poster Join Date: Nov 2003 Location: At The Shop
Member: 43098 Status: Offline Thanks Meter: 71 | Does this new method work with rSim 15? The dual card version in the pink plastic case? I can verify it works with rSim 14 for the XR series in the green plastic case. |
03-12-2020, 02:34 | #21 (permalink) |
Member: 2213455 Status: Offline Thanks Meter: 17 | And don't forget that rsim cant relase update for user With new ios apple like before open iccid active You can active with any unlocker sim with any version . Good luck |
03-12-2020, 04:53 | #22 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,694 | V19.1 and v19.2 is working too , the net worker will upload the v19.3 today , |
The Following User Says Thank You to kinglock For This Useful Post: |
03-12-2020, 05:24 | #23 (permalink) |
Junior Member Join Date: Jul 2008
Member: 824955 Status: Offline Thanks Meter: 2 | Osea ustedes no tenían preparada la actualización para Dongle de rsim 15 y esto fue un golpe de suerte que les ha traído de vuelta al negocio ? Nos edtaban mintiendo al hacer esperar por algo que no había y ahora con suerte bum regresaron , pero hasta cuándo será esto ? |
03-12-2020, 06:41 | #24 (permalink) | |
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,694 | Quote:
http://www.rsim5.com/intro.php?id=14 | |
03-12-2020, 17:25 | #26 (permalink) |
Insane Poster Join Date: Jan 2008 Location: Santiago , DR
Member: 670004 Status: Offline Thanks Meter: 7 | yes, jailbreakit and modified some files on the os, and iccid gonna work , google it |
The Following User Says Thank You to EL_SaNdUnGuErO For This Useful Post: |
03-13-2020, 14:03 | #28 (permalink) | |
Insane Poster Join Date: Feb 2017 Location: Ukraine Age: 55
Member: 2683247 Status: Offline Thanks Meter: 19 | Quote:
For users below the iPhone 6S (i5 / 5C / 5S / 6 / 6Plus) who want to use the ICCID unlock method, they need to jailbreak their iPhone. From Cydia, install Filza File Manager. Open Filza, then go to System / Library / Coreservices. There you will find the SystemVersion.plist file. Open this file and you will find ProductBuildVersion. We need to change the value of this ProductBuildVersion to 17D50. Then come back, you will find ProductVersion, and we need to change the value to 13.3.1 and save. Now hard reset your iPhone. Your device will show software version 13.3.1 (17D50) Now you can unlock your device using the ICCID unlock method After activation by ICCID, return the version and number of your firmware via jailbreak. Last edited by Tolbas; 03-13-2020 at 14:09. | |
The Following User Says Thank You to Tolbas For This Useful Post: |
03-14-2020, 18:16 | #30 (permalink) |
Member: 2683247 Status: Offline Thanks Meter: 19 | Activation by ICCID iPhone 6, 6+ and 5s: 1.We take the phone, put the jail checkrain 0.9.8.2. 2. We go into the side and put Filza File Manager and Apple File Conduit “2” 3. Through Filza we go along the path System / Libraries / Coreservices. Copy the SystemVersion.plist file to the same folder. The file will be called SystemVersion (1) .plist 4. Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion to 17D50. Then we return and in ProductVersion we change the value to 13.3.1. Click save and done. 5. We reboot the device with the buttons. The download will be long, with a running status bar. 6. After loading the device, insert the sandwich and enter the current ICCID in the drop-down menu. 7. We go through the activation and we have a fully functioning device. (will not work without a gasket) Now return the firmware version: 1. We take the phone, again we put the jail checkrain 0.9.8.2. 2. Thanks to the Apple File Conduit “2” tweak installed earlier, we connect the phone to any program (iTools, 3Utools, etc.) and go to the “File System” section. 3. In 3Utools, as an example, we go along the path System / Libraries / Coreservices. Delete the SystemVersion.plist file and rename the previously copied source file named SystemVersion (1) .plist to SystemVersion.plist. That is, without "(1)". 4. We reboot the device with the buttons. The download will be long, with a running status bar. That's all. The phone remains on the old firmware 12.4.x and works as a non-wizard. After all the manipulations, all applications work stably, both old and just installed. |
