08-29-2019, 19:44 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2014 Location: Worldwide Age: 32
Member: 2274876 Status: Offline Sonork: n/a Thanks Meter: 24 | So, Any One Solved Problem With Rsim12+ ? |
08-30-2019, 03:54 | #3 (permalink) |
Product Manager Join Date: Oct 2013 Location: USA
Member: 2048513 Status: Offline Thanks Meter: 157 | R-SIM14 V18 Mai MAUNAL unlock for iphoneXS MAX Sprint ios12.4 https://www.youtube.com/watch?v=TeF4xno8WEo How to use R-SIM12 V16 Mai TMSI AUTO unlock for iphone ios12.4 https://www.youtube.com/watch?v=ilpQU9oF6NA RSIM Mai TMSI MAUNAL unlock https://www.youtube.com/watch?v=Af3huaO6ewk RSIM 14 v18 sprint a Unefon agosto 2019 https://www.youtube.com/watch?v=RIEk...ture=********* No need to change the iccid, go to the next step directly . Use default iccid in rsim |
The Following User Says Thank You to R-sim For This Useful Post: |
08-30-2019, 08:00 | #4 (permalink) | |
Member: 2274876 Status: Offline Sonork: n/a Thanks Meter: 24 | Quote:
still no service. tryed all methods dont changed iccd | |
The Following 2 Users Say Thank You to chanchura123 For This Useful Post: |
08-30-2019, 21:11 | #6 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Quote:
All lies. You are back on your lies like you use to do in the past. Chinesse fuc**ng liers!! | |
08-30-2019, 22:41 | #7 (permalink) | |
Freak Poster Join Date: Apr 2014 Location: GSMWORLD
Member: 2171849 Status: Offline Sonork: no Thanks Meter: 110 | Quote:
08-30-2019, 23:42 | #8 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: San Pedro Sula
Member: 909015 Status: Offline Thanks Meter: 75 | Quote:
Stop posting proof videos that only was working for a short time. | |
09-02-2019, 03:56 | #13 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 474604 Status: Offline Thanks Meter: 11 | Quote:
ok ppl i got two iPhones to work (sprint XsMax, AT&T XR) and I got 3G/LTE to work as well so this is my method used on both the trick if you want to call it that is make sure data roaming is on to get LTE/3G working 1. I used rsim 12+ 16.1 on both phones but the method will work with 14+ 18.1 as well 2. select at&t no matter the carrier the phone is from 3. select manual TMSI mode 4. input a latest working ICCID used 89014104279605339274 5. click accept at the prompt punch out the simtray and put back in it will take you to activation screen with no signal bar click continue and the phone should activate with no service go back to sim applications and click on regain sim signal punch out simtray and push back in again once you've used a working ICCID at the activation screen when you regain sim signal after a Lil bit you should be taken to the home screen with either service from whatever sim carrier in the phone if it says no service just wait and it will come up at this point switch off wifi make sure data is on, LTE is on and data roaming is on and thats it if is doesnt work try another iccid and go through method again | |
The Following User Says Thank You to aldean2000 For This Useful Post: |
09-02-2019, 09:04 | #14 (permalink) | |
this method not work for me. sim not supported. try with emergency call activated but also does not work, still no service | |
09-02-2019, 12:22 | #15 (permalink) | |
89014104270225987873 89014104270225987584 89014104270225993202 89014103270421620683 89014103270421624800 89014103270421624453 Try one of these | |
