Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 11-11-2017, 12:34   #211 (permalink)
Member: 2767323
Good day
Good day, please send a link to the seller of working chips
Old 11-11-2017, 15:37   #212 (permalink)
Member: 2767141
Thanks Meter: 18
Originally Posted by Edward Gein View Post
Anyone knows which option to choose for Docomo japenese lock ?
When carrier select pop up came out u just select jp docomo or just input imsi code 4401020
Sent from my iPhone using Tapatalk
Old 11-16-2017, 17:22   #213 (permalink)
Member: 1455652
Heyas guys.
Hi guys!
I've seen all the posts respecting what each one of you have gone through since the recent update to this version of ios, lower versions of ios are working without no problem and my recommendation to you guys is to restore to a previos version of ios where you can have a full compatibility of the device.
It's required an intermediate sort of knowledge on ios restorations to achieve the best possible results.
Thanks in advance and I really hope we all can walk through this little technical issue hand by hand.
As for the RSIM technical team we the customers need a sooner answer about how to perform in a proper way a fix to our needs, our investments are the founds you are using for your research and end up technology and also a better support to achieve our mutual interest.
The rest of the process should be done as smooth as the first time you did, for those having an issue with NO SIM notifications it might be because you just ****ed up the RSIM so try it out in another device and double check if it is working if not buy a new one, and for those trying to get to the pop up menu or to the settings menu you should pay attention to what have been said in this post and remember that apple can stop signing lower versions of ios for your iDevices at any time so you better rush your asses and get your iDevices up and running once again.
f47h3r.
Old 11-17-2017, 06:42   #214 (permalink)
Member: 1484663
Thanks Meter: 344
Exclamation
Originally Posted by f47h3r View Post
Hi guys!
f47h3r.
Who are you? Such stupid post! Yes auto-unlock solution was great but now it's gone and mister Kinglock it's showing some useless videos of R-sim working with iPhone 5S and so. He just panicked about loosing money on R-Sim 11+.
Yes R-Sim 11+ is the best so far I'm using it to unlock some older iPhone models. But just let's not forget R-sim 10 and 10+ Those were pure CRAP and many people complained about it. So don't come up telling us how to use R-sim 11+ This is has Noting to do with restoring to previous versions (wich is almost impossible for most models you donkey) It's all about Apple closing a vulnerability. So stop posting Crap and shut your stupid *****!
Old 01-01-2018, 16:02   #215 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,693
https://www.youtube.com/watch?v=F0R-URnMu9Q
Old 01-01-2018, 16:43   #216 (permalink)
Member: 2765412
Thanks Meter: 12
Will this method work on Sprint?
Old 01-01-2018, 19:15   #217 (permalink)
Member: 2765412
Thanks Meter: 12
89860600502000180722
Someone should try this code
Old 01-02-2018, 13:09   #218 (permalink)
Member: 1768975
Sonork: 1615342:cikaaca
Thanks Meter: 50
that the old one b4 the last one
Old 01-02-2018, 17:08   #219 (permalink)
Member: 2596108
Thanks Meter: 58
That was the working code that was blocked dude lmao
Old 01-02-2018, 20:22   #220 (permalink)
Member: 1484663
Thanks Meter: 344
Got to wait for new ICID or new unlocking method.
Old 01-03-2018, 01:23   #221 (permalink)
Member: 2156601
Thanks Meter: 3
Call fail
Originally Posted by kinglock View Post
Getting call failed using tmsi methos
Old 01-03-2018, 02:17   #222 (permalink)
Member: 1862624
all method not working
I have more 100pcs r-sim, please give solution, new ICCID, or other methods for unlock iphone!
Old 01-03-2018, 16:15   #223 (permalink)
Member: 1829499
Thanks Meter: 2
I just tried a JP Docomo with ICCID change and selecting Docomo. Also inserted IMSI but no luck. I am using Rsim12 9.1
Old 01-05-2018, 15:52   #224 (permalink)
Member: 1907775
Thanks Meter: 2,693
Thanks for RSIM engineers team's hard work,The new ICCID code has been found in 2018/01/04 .
ICCID-1
8901000000000000001f
ICCID-2
89010000000000000q1f
http://forum.gsmhosting.com/vbb/f819...sim12-2304539/
The best to all rsim user. all the new verizon V9.3-- RSIM12 no need setting , plug and play . Welcome order
Old 01-06-2018, 12:26   #225 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 44
Please do as the video
RSIM12
https://www.youtube.com/watch?v=6dqXXFjxLlE
video1:RSIM11+ Unlock For iOS11
https://www.youtube.com/watch?v=rW_a1Tb1YZI
video2:
https://www.youtube.com/watch?v=fHg095L240Q
video 3:
https://www.youtube.com/watch?v=J7mePcuAY2k
video 4:
https://www.youtube.com/watch?v=cFbL...ture=*********
The instructions for RSIM11+ return to unlock menu
3th Home button Emergency Call
4th Call *5005*7672*0#
5th:
Settings SIM Applications
Lock Carrier
Return to TMSI unlock mode. Mobile Operation Flow Method①Ignore WiFi, open cellular data, data roaming, close 4G.
First adjust the card patch operator, insert the card + mobile card, input *5005 * 7672 * 11 # mobile phone will automatically find the mobile 2G signal, then open 4G on the OK method②good card paste. Close 4G, insert the card separately, and automatically jump to the upper-left corner of the activation screen to display 3G or E. Emergency dialing 112 to remain on and back out. Plug in the card and the phone card. Wait for 2G signal to appear, open 4G then. (Switch flight mode if a hollow signal appears during operation)
Methodology③
Switch on the card, insert the mobile card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off thoroughly). Then pull out the card and install the card and the mobile card. Turn it on and wait for the signal.
Method④There are many methods to move 4G, but I wont go through them here.
Unicom 4G operation method
Method①Put the card in place, insert the 4G card separately, appear 5 points plus 4G, emergency dialing 112, hold 112 for 5-8 seconds, switch to 5 points plus 3G, pull out the card directly, plug in the card sticker and the card, automatically send out the signal.
Telecom 4G Operation Method
Method①Adjust the card, dial the *5005*7672*11# code, and then prompt a message to restart the machine.
Methodology②
Switch on the card, plug in the card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off completely). Then pull out the card and install the card and the card. Turn it on and wait for the signal.
Operator Boot Directive *5005*7672*00#
Search signal instruction*5005*7672*11#
Carrier code:
R-SIM12,GPP,GEVEY,HEICARD,HEISIM,RSIM 10,RSIM11+,RSIM 9 PRO mini air Unlock,iPhoneX,iPhone8,Firmware,Any version, No jailbreak
after doing all this and it get to home it revert back to activation
Page generated in 0.23213 seconds with 10 queries
