Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 10-07-2017, 02:53   #46 (permalink)
Member: 2575858
Thanks Meter: 20
Hey guys I currently don't have an iPhone but one of my other Tech friends just sent me this info I don't have an iPhone in hand to test with somebody let me know success with this method please....
"New solution for 6s/6sp/se/7/7pput chip and mobile sim into iphone ----it go activaion---- press HOME , emergency call -------enter *5005*7672*0# ,pls dia it once you see the left corner show signal point or no service ,---menu jump out ----select correct carrier ------select 6S/6SP/SE mode,--- activate it , next wait 4g signal come out ."
@Luistmw
Sent from my SM-G955U using Tapatalk
Old 10-07-2017, 02:58   #47 (permalink)
Member: 2671186
Thanks Meter: 2
why im always no sim?
i buy rsim11+ yesterday
but still no sim
its that effect from apple patched for rsim?
or my rsim error
plz i need answer
Old 10-07-2017, 02:59   #48 (permalink)
Member: 2575858
Thanks Meter: 20
but still no sim
or my rsim error
plz i need answer
Read our full post and help us troubleshoot friend
Old 10-07-2017, 04:38   #49 (permalink)
Member: 2764641
Thanks Meter: 8
I try that but only by pass the activation screen
Old 10-07-2017, 05:32   #50 (permalink)
Member: 2575858
Thanks Meter: 20
Then go to settings phone SIM applications select correct carrier then select 6s mode
Old 10-07-2017, 06:08   #51 (permalink)
Member: 2575858
Thanks Meter: 20
Originally Posted by kinglock View Post
Return to TMSI unlock mode. Mobile Operation Flow Method①Ignore WiFi, open cellular data, data roaming, close 4G.
First adjust the card patch operator, insert the card + mobile card, input *5005 * 7672 * 11 # mobile phone will automatically find the mobile 2G signal, then open 4G on the OK method②good card paste. Close 4G, insert the card separately, and automatically jump to the upper-left corner of the activation screen to display 3G or E. Emergency dialing 112 to remain on and back out. Plug in the card and the phone card. Wait for 2G signal to appear, open 4G then. (Switch flight mode if a hollow signal appears during operation)
Methodology③
Switch on the card, insert the mobile card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off thoroughly). Then pull out the card and install the card and the mobile card. Turn it on and wait for the signal.
Method④There are many methods to move 4G, but I wont go through them here.
Unicom 4G operation method
Method①Put the card in place, insert the 4G card separately, appear 5 points plus 4G, emergency dialing 112, hold 112 for 5-8 seconds, switch to 5 points plus 3G, pull out the card directly, plug in the card sticker and the card, automatically send out the signal.
Telecom 4G Operation Method
Method①Adjust the card, dial the *5005*7672*11# code, and then prompt a message to restart the machine.
Methodology②
Switch on the card, plug in the card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off completely). Then pull out the card and install the card and the card. Turn it on and wait for the signal.
Operator Boot Directive *5005*7672*00#
Search signal instruction*5005*7672*11#
Is there a way we can confirm that Apple completely blocked us and this method and rsim11+ is not working so that way we don't waste time with the work around and troubleshooting!
Or have there been some with success???
Old 10-07-2017, 09:11   #52 (permalink)
kanokh's Avatar
Member: 1736804
Sonork: 100.1644836
Thanks Meter: 433
Not work
Methodology③
Methodology②
Not work iOS 11 2g / 4g
Old 10-07-2017, 10:38   #53 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,473
Originally Posted by retaco82 View Post
Can u clarify step by step? i have 300 rsims i had left over and need a solution
do it as the pic step by step
Old 10-07-2017, 12:24   #54 (permalink)
Member: 612439
Thanks Meter: 34
after that phone is active but still no service
Old 10-07-2017, 13:32   #55 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
Methodology③
Methodology②
Old 10-07-2017, 18:29   #56 (permalink)
Member: 2575858
Thanks Meter: 20
Here are my results when it is on searching I can make it to home screen when I have 3-g service I get stuck at SIM card not supported I do try *5005*7672*0*
And I get settings succeeded service center address no address...
The Following User Says Thank You to diazdetail626 For This Useful Post:
Old 10-07-2017, 21:13   #57 (permalink)
Member: 1938435
Thanks Meter: 208
Yes this is the whole point of this topic. You got to wait for someone to discover a new bug and buy a new chip or be lucky enough to have an upgradable chip and an update dongle.
Old 10-07-2017, 21:18   #58 (permalink)
Member: 2575858
Thanks Meter: 20
The method has been discovered and has been bypass successfully by some we don't know yet if the chips have been blocked or if there's another bypass method we need to be able to make sure 100% if they have been blocked and no one has bypassed successfully or if somebody has successfully bypassed.... this question is still in the air unanswered!
Old 10-07-2017, 22:19   #59 (permalink)
Member: 2765523
Thanks Meter: 6
Here are my best results of 2 day researching our problem guys
3G connection works
Outgoing calls work(can`t hear outgoing voice, no problem with incoming voice)
No incoming call
Sms service also doesn`t work.
Sorry I`m new here and it doesn`t allow me to post links... Took a few pics wanted to share...
The Following User Says Thank You to bmu777 For This Useful Post:
Old 10-07-2017, 22:21   #60 (permalink)
Member: 2575858
Thanks Meter: 20
3G connection works
No incoming call
Even though it's not the best news, it is actually still good news to hear.... you seem to have had better luck than the majority of us!!!
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.22974 seconds with 8 queries
