Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 10-10-2017, 16:49   #106 (permalink)
ffhfox's Avatar
Member: 296215
Thanks Meter: 57
hi friends post any testing solutions, for test
The Following User Says Thank You to ffhfox For This Useful Post:
Old 10-10-2017, 16:57   #107 (permalink)
Member: 2575858
Thanks Meter: 20
Originally Posted by gugbobgug View Post
ok find good luck
all what is for sale on ebay works same technology as r sim ! and all is copy version for $3 !
and only original r sim have programing option ! and even original r sim
when you make unlock does not work outgoing calls ! and signal does not work in standby mode !
Again were trying to find a solution, not buy more chips, u are not the only one in WORLD with this card.. if our r-sim 11 + is dead then I don't mind waiting... if we must wait for a new card to get 4G network then I guess we must wait but to settle for something with 3g would not suffice here in the United States were 5g is due soon!
Yes you made it work but again not perfect!
No matter what WE ALL need new Chips now for 4G
Sent from my SM-G955U using Tapatalk
Old 10-10-2017, 18:00   #108 (permalink)
Member: 2357447
Sonork: dosrun
i will be very happy if we have new r sim card wich will work for 4g
Old 10-10-2017, 18:08   #109 (permalink)
Member: 2596108
Thanks Meter: 58
Could anyone confirm the supposed solutions that king lock posted with those vids
Sent from my SM-G950F using Tapatalk
Old 10-10-2017, 18:11   #110 (permalink)
Member: 2671186
Thanks Meter: 2
carrier you can check GSX
$ 0.5 need
ok done i know what my carriers too
its KDDI japan au
so about simcard
must be 3G simcard only?
or 4G can too?
ip5 63gb 10.3.3 kddi au japan
Old 10-10-2017, 18:23   #111 (permalink)
Member: 2765770
Thanks Meter: 6
I have watched the youtube videos.
When I insert rsim 11+ and sim card, it does not launch the rsim menu???
Any one have a solution?
Have I corrupted the rsims with all the other methods I tried?
My rsims and phones worked perfectly before 5 October so I know the rsims are good.
Thanks all. Keep the faith for a solution!!
Old 10-10-2017, 19:29   #112 (permalink)
Member: 2587002
Type on emergency call *5005*7672*00# or *5005*7672*0#you will get the menu
Old 10-10-2017, 20:38   #113 (permalink)
Member: 2587002
Can you tell if ussd codes works after that fix?
Old 10-10-2017, 21:51   #114 (permalink)
Member: 2766699
When I try to dial *5005*7672*00# I am getting:
Settings Succeed
Service Centre Address
No address
and dismiss button
I don't have any cariers options
Any Ideas ?
Old 10-10-2017, 22:23   #115 (permalink)
Member: 2587002
Settings Succeed
No address
and dismiss button
Any Ideas ?
When i get that i reboot the get the menu again through the code *5005*7672*00#
Old 10-10-2017, 22:32   #116 (permalink)
Member: 2766699
Tried several times *5005*7672*00#, *5005*7672*0#, *5005*7672*11#, *5005*7672*44#,
with restart, without restart, with 3g, with 4g card. Nothing. Always the same. Iphone SE 11.0.2 and Iphone 5 9.x.x
Old 10-11-2017, 03:09   #117 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,776
https://www.youtube.com/watch?v=cFbL...ture=*********
The Following User Says Thank You to kinglock For This Useful Post:
Old 10-11-2017, 03:14   #118 (permalink)
Member: 2082736
Thanks Meter: 16
NEED Q-sim 2 pop-up menu code
Old 10-11-2017, 03:16   #119 (permalink)
Member: 2596108
Thanks Meter: 58
my RSIM menu doens't have those modes, unlock1/unlock2 USIM, mode 1. It's limited, is there a solution?
Old 10-11-2017, 08:06   #120 (permalink)
Member: 2765770
Thanks Meter: 6
Hi
Nothing works. None of these codes. I tried different sim cards different rsims.
Reoboot, retry again and again.
Always get:
Setting succeeded
Service centre address
No address
Iphone 5S Locked to T Mobile.
Rsim worked very well before 5 October.
Thanks
Page generated in 0.19755 seconds with 9 queries
