Hey guys I currently don't have an iPhone but one of my other Tech friends just sent me this info I don't have an iPhone in hand to test with somebody let me know success with this method please.... "New solution for 6s/6sp/se/7/7pput chip and mobile sim into iphone ----it go activaion---- press HOME , emergency call -------enter *5005*7672*0# ,pls dia it once you see the left corner show signal point or no service ,---menu jump out ----select correct carrier ------select 6S/6SP/SE mode,--- activate it , next wait 4g signal come out ." @Luistmw Sent from my SM-G955U using Tapatalk |
why im always no sim? i buy rsim11+ yesterday but still no sim its that effect from apple patched for rsim? or my rsim error plz i need answer |
I try that but only by pass the activation screen |
Then go to settings phone SIM applications select correct carrier then select 6s mode Sent from my SM-G955U using Tapatalk |
Or have there been some with success??? Sent from my SM-G955U using Tapatalk |
Not work Quote:
Not work iOS 11:eek::eek::eek: 2g / 4g |
First adjust the card patch operator, insert the card + mobile card, input *5005 * 7672 * 11 # mobile phone will automatically find the mobile 2G signal, then open 4G on the OK method②good card paste. Close 4G, insert the card separately, and automatically jump to the upper-left corner of the activation screen to display 3G or E. Emergency dialing 112 to remain on and back out. Plug in the card and the phone card. Wait for 2G signal to appear, open 4G then. (Switch flight mode if a hollow signal appears during operation) Methodology③ Switch on the card, insert the mobile card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off thoroughly). Then pull out the card and install the card and the mobile card. Turn it on and wait for the signal. Method④There are many methods to move 4G, but I wont go through them here. Unicom 4G operation method Method①Put the card in place, insert the 4G card separately, appear 5 points plus 4G, emergency dialing 112, hold 112 for 5-8 seconds, switch to 5 points plus 3G, pull out the card directly, plug in the card sticker and the card, automatically send out the signal. Telecom 4G Operation Method Method①Adjust the card, dial the *5005*7672*11# code, and then prompt a message to restart the machine. Methodology② Switch on the card, plug in the card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off completely). Then pull out the card and install the card and the card. Turn it on and wait for the signal. Operator Boot Directive *5005*7672*00# Search signal instruction*5005*7672*11# |
Here are my results when it is on searching I can make it to home screen when I have 3-g service I get stuck at SIM card not supported I do try *5005*7672*0* And I get settings succeeded service center address no address...https://uploads.tapatalk-cdn.com/201...65e546bd36.jpghttps://uploads.tapatalk-cdn.com/201...7f852a8755.jpghttps://uploads.tapatalk-cdn.com/201...fd6edc8523.jpghttps://uploads.tapatalk-cdn.com/201...7d30b3ae72.jpghttps://uploads.tapatalk-cdn.com/201...b272cd0e29.jpg Sent from my SM-G955U using Tapatalk |
Here are my best results of 2 day researching our problem guys :( 3G connection works Outgoing calls work(can`t hear outgoing voice, no problem with incoming voice) No incoming call Sms service also doesn`t work. Sorry I`m new here and it doesn`t allow me to post links... Took a few pics wanted to share... |
