10-15-2017, 05:12 | #153 (permalink) |
Freak Poster Join Date: May 2016
Member: 2575858 Status: Offline Thanks Meter: 20 | I have somewhat got it to work with the standard rsim 11 plus but as you can see in the picture it says no service but I I'm able to receive a phone call, when I make a phone call it only tells me that my phone is not allowed to make phone calls to this number at this time Sent from my SM-N950U using Tapatalk |
10-15-2017, 05:18 | #154 (permalink) |
Member: 2575858 Status: Offline Thanks Meter: 20 | 1) go into it until it says SIM card not supported and then dial the number sequence on the emergency dialer to get your Rsim menu... 2) when you're at the menu click the last option where it says tsmi mode 3) restart the device after you click that and you should be left with no service 4) once you are left with no service, the iPhone will now let you go to the home menu from the whole menu go to settings phone then Sim applications.. 5) from SIM applications to 6s special mode but do not restart you should get your signal bar but it tends to come and go with me if you see the picture above it shows no service but it lets me make a phone call Sent from my SM-N950U using Tapatalk |
10-15-2017, 05:28 | #156 (permalink) |
Member: 2575858 Status: Offline Thanks Meter: 20 | So I guess all going phone calls is not allowed it says that my account is not allowed to make phone calls to this number Sent from my SM-N950U using Tapatalk Last edited by diazdetail626; 10-15-2017 at 07:01. |
10-16-2017, 00:05 | #157 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2768442 Status: Offline Thanks Meter: 1 | iPhone 7 Plus AU KDDI Lock IOS 11.0.1 Hi guys, I`m unable to Activate this phone with r-sim 11+ after I updated it thru the Itunes to 11.0.1. Is there any other way to do it? Or just wait for R-sim 12? Thx in advance. |
10-17-2017, 10:28 | #158 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | RSIM11+ for ios11--LTE V19 9 AUTO MODE https://www.youtube.com/watch?v=MWL0q5IPGFU NEW V19.9 AUTO MODE for ios11--LTE https://www.youtube.com/watch?v=iB6-...ture=********* |
10-17-2017, 14:05 | #160 (permalink) | |
Junior Member Join Date: Mar 2007
Member: 474158 Status: Offline Thanks Meter: 3 | WARNING :- RSIM 12 will not work for all carrier. Quote:
Warning :- RSIM 12 will NOT work on ALL carriers. There are preconditions to be met for the auto mode to work on your locked iphone and the most important one is to have the IMSI / TMSI of your phone. if your phone IMSI or TMSI is known or preprogram into the RSIM then you are in luck. or else just too bad. so most Tracfone phone owners, we are in the same boat now. i hope this can clarify to those newbies reading the thread and dont come here to cry father cry mother due to RSIM failing your expectation. | |
10-18-2017, 16:35 | #162 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2671186 Status: Offline Thanks Meter: 2 | i have method n works really nice on me maybe its works on u too http://forum.gsmhosting.com/vbb/f819...3-3-a-2276473/ |
10-20-2017, 15:46 | #164 (permalink) | |
Junior Member Join Date: May 2017
Member: 2718431 Status: Offline Thanks Meter: 2 | Quote:
Anybody planned to answer on problem with no incoming call on screen lock? What support you have if nobody not answer, just ignoring!!Say somthing.. or say as this rsim not work more....not to wait in vain | |
10-20-2017, 15:55 | #165 (permalink) |
No Life Poster Join Date: Mar 2014
Member: 2156606 Status: Offline Thanks Meter: 21 | Hello guys, I made my iPhone 6 working again after update and reset by downgrading iOS to 11.0.1 and activating it with Rsim 10+, it is working normally as before. Also I tried it with Rsim 11+ which I preprogrammed on other iPhone with locked Rsim settings, it was working normally as before also. So, downgrade guys, while you still can. I hope I helped somebody by sharing this. Wont upgrade it until some solution is found. |
