11-19-2014, 01:03 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2272731 Status: Offline Thanks Meter: 3 | Sprint ios 8.1 everything working (tutorial) I've managed to unlock my iPhone while using 7.1.2 as well as 8.1 now Steps : 1. Sometimes it will display "No service" and sometimes will display your network name in my case "Ufone". And you'd be getting activation errors. 2. For me I can make calls and receive them, also I can receive messages but fail to send them out and internet does not work. 3. Jailbreak your iPhone (it's iPhone 5 in my case) 4. Install Filza/iFile (I installed Filza because I couldn't get ifile to work) 5. Head over to System/Library/Carrier Bundles/iPhone/Sprint_LTE_US. Bundle 5. Delete all the files inside 6. Reboot 7. It will say No Service at first but after just 1 minute it will display your network name. Walaaaah! Your iPhone is now up and ready to be used. Notice it says Carrier 18.0 at Carrier in settings>>general>>about You can now edit your apns and use your internet. I'm still searching for a way to get imessage and FaceTime working with my number, I'll update you guys when I'm done figuring it out Last edited by awaisthebest; 11-19-2014 at 01:08. |
The Following 3 Users Say Thank You to awaisthebest For This Useful Post: |
11-19-2014, 09:53 | #3 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2274130 Status: Offline Thanks Meter: 16 | On iphone 5 Sprint works any R-Sim9 Pro, R-Sim mini 2, R-Sim 9 + Nano, R-Sim Air 2. It's not problem with iphone 5. For 3g-2g use 3gpp or apn.lockedit etc. Only problem is iphone 5s, 6, 6+, Sprint iOS 8.x |
11-19-2014, 13:45 | #4 (permalink) | |
Freak Poster Join Date: Feb 2013
Member: 1886860 Status: Offline Thanks Meter: 21 | Quote:
but what is solution for activation loop when signal lost ??/ | |
11-19-2014, 14:12 | #5 (permalink) |
Junior Member Join Date: Nov 2006
Member: 396431 Status: Offline Thanks Meter: 0 | why would you put "everything working" in the title and then post "still searching for a way to get imessage and FaceTime working" ? You have only gotten as far as I have. (4s Sprint with R-Sim 6 which was working for 7.1.1 - I updated at the last minute to take advantage of 8.1 jailbreak...kind of wish I didn't now) As Nilu posted, I go into activation loop after a while, especially when I lose signal. |
11-19-2014, 15:18 | #6 (permalink) | |
11-19-2014, 16:36 | #7 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | The activation loop problem can be mitigated by changing the carrier bundle. I think some bundles cause looping more than others. I use the TMobile_US.bundle and don't see the activation loop on 4S, but it's an issue with 5S/5C/6/6+ iPhones. Your iMessage/FaceTime requires a number in Settings, Phone, My Number. I can fix this for you if you don't have a number here. 4S automatically fixes it as well as 5C/5S/6/6+. 5 can be fixed by using the Mini 2/9+/Air 2 in 5s/5c mode, but you have to delete setup.app and such, which may prevent 3G incoming calls/texts for many carriers. I can register the MEID to avoid that issue as long as it's clean. |
The Following User Says Thank You to SIMTester For This Useful Post: |
11-22-2014, 11:42 | #12 (permalink) |
Member: 2272731 Status: Offline Thanks Meter: 3 | I'm using goguo. I've tried various sims and all of them seems to be working. Can you tell me what problem are you facing in Japan? P.S Can you explain me what happens when the activation loop occurs? When I change my carrier bundles I get activated message after which I never get activation issues. I've restored my iPhone 5 twice to check if this method is really working fine, and yes it is |
11-22-2014, 13:02 | #13 (permalink) | |
and bro R-sim working on iPhone 5 perfectly till latest iOS 8.1.1 . the main problem is in iPhone 5S bro | |
11-22-2014, 13:40 | #14 (permalink) | |
Member: 2272731 Status: Offline Thanks Meter: 3 | Quote:
11-22-2014, 22:45 | #15 (permalink) | |
we're I'm saying that not do anything on sprint iphone 5 ??? iI'm saying that iPhone 5S unlock has very difficult then iPhone 5 to work perfectly using R-sim | |
