05-19-2014, 03:22 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2011550 Status: Offline Thanks Meter: 9 | Unlocking iPhone 5c Sprint 7.1.1 Rsim Air2 OK but it has some problems ...(see the bottom of the post to see what im talking about) so... lets get started. first of all you will need -Freshly Restored iPhone 5S/5C to iOS 7.1.1 -Rsim Air2 -Rsim 9 Pro or any Rsim that loops into activation mode(i used Heicardsim 3 because my 9pro is broken ._. so..) -your Sim -Sprint nano Sim (i had this one but i think that is optional because to activate the CDMA on the iphone is enough with the 9pro , i will try it on the i5s this way and update this post if that not works) -a beer (:P) let`s start: 1:well as usual we need to activate the iphone for the first time using the sprint sim 2: go to settings and deactivate Data on Cellular data 3: insert your Sim with the Rsim 9 pro(or the rsim you have,Not the air2!) and let the activation loop begin and dont go further on the setup 4: remove the rsim 9 pro(or the rsim you have,Not the air2!) 5 :insert your Rsim Air 2 with your sim 6:Wait untill you get no service and you will recieve a pop up about activation (time to grab the beer :P) 7:to test that everything is going according to the plan try to make a call while you have No Service and if the call goes fine then you gotta keep waiting untill you get signal (keep enjoying the beer ) 7:you will get a pop up about the registration is not complete ,now your touch on ignore and you will get your carrier name and the signal 8 : DONE now you will face the same problem as me ... incoming calls are not working,data or SMS ... so i shared this to see if someone found a solution for this . i tested many many of the methods on this forum and none of them worked and falled into the doomed activation loop ... this is the only method that worked for me to get stable signal (full bars) and outgoing calls... i dont have enough post's to show you my images so im gonna chop the links for the moment. (just remove all the spaces and replace the ''dot'' with a ''.'' i58 dot serv img dot com / u / f58 / 12 / 16 / 00 / 75 / img_0010 . jpg i58 dot serv img dot com / u / f58 / 12 / 16 / 00 / 75 / img_0010 . png |
The Following User Says Thank You to KonataRola For This Useful Post: |
06-17-2014, 16:41 | #4 (permalink) |
Junior Member Join Date: Nov 2008 Location: Springfield
Member: 907630 Status: Offline Thanks Meter: 1 | I cant activate my Sprint 5c 7.1.1, i just want to make calls, it always redirects me to activation screen, please help me. I don't have sprint sim, because im from Perú. |
06-22-2014, 08:36 | #8 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Everyday, I check the forums hoping for a breakthrough to get RSIM Mini or RSIM Air 2 working with any SIM card without any activation loop. I'll test this method tomorrow and post my results. |
06-22-2014, 14:11 | #10 (permalink) | ||
Freak Poster Join Date: May 2014
Member: 2184212 Status: Offline Thanks Meter: 19 | Quote:
every sometime it went back to activation again and very difficult to unlock again tired of doing this.... | ||
