Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > Avengers Box
Avengers Box (Multi Unlocker Box)
Old 12-06-2020, 17:39   #1 (permalink)
Member: 2526196
Thanks Meter: 60
Help! Asus Zenfone L1 Za550kl X00RD NO Loader Firehose Avengers Qualcomm
Exe Version: Avengers Qualcomm Module 0.12.8
Operation: Read Info
Searching for phone.....
Qualcomm HS-USB QDLoader 9008 (COM25) detected.
Hello received.
HW ID: 01003412E1600500
PK HASH: 2F8ADBCC54D88F4822B939741A9DE84FA20A9218A6BD3C93B0 86B34EA72DAF63
Checking database for suitable loader.....
Arhitecture:32 bits
[32]Sending loader, please wait..
Loader not accepted by phone.
Please select manually loader for this cpu.
[0]You must find phone firmware and use loader what come with firmware.
Old 12-06-2020, 19:56   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Check this loader if work and repply if ok or not.
Old 12-07-2020, 18:25   #3 (permalink)
Member: 2526196
Thanks Meter: 60
Hello received.
Using custom loader: prog_emmc_firehose_8917_ddr.mbn
Arhitecture:32 bits
Error untill sending loader!
Old 12-07-2020, 23:39   #4 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
this phone exists in 3 versions, with 2 gb ram, 3gb ram and go version with 1 gb ram.
And posible loaders is not compatible between.
Firmware is easy to find, it take me 5 min to find firmware and download it.
So try to search version for your phone.
If will not work with any loader, then posible exists problem with your phone or connection between pc and phone.
Old 12-08-2020, 15:01   #5 (permalink)
Member: 2526196
Thanks Meter: 60
The Firmware was already downloaded but the Loader that was inside the firmware did not work, I used several USB cable and it was also used in several PCs And nothing And the phone is New Sealed It has never been opened or worked by Third parties
Old 12-08-2020, 22:34   #6 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good to have if this custom loader works for you, remember that there are three models of this asus and do test point.
Custom Loader: https://www.androidfilehost.com/?fid...59528675600245
Old 12-09-2020, 16:10   #7 (permalink)
Member: 2526196
Thanks Meter: 60
Hello received.
Using custom loader: prog_emmc_firehose_8937_ddr_asus3.mbn
Arhitecture:32 bits
If in that I am clear that there are 3 different models of that model, I have looked for several chargers for this model on the net and none have worked
Page generated in 0.21031 seconds with 9 queries
