Avengers Box (Multi Unlocker Box) |
07-10-2021, 16:43 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | Avengers Box / UMT Pro Android MTK Module v.0.7.8 Update Released [10/07/2021] - Changed Bypass security function. -- Now it become more fast, and take 2..3 sec in new exe version to bypass security. - Enabled dump Preloader and EMMI initialization for not secure phones booted in Brom mode. -- This feature allow to not use Preloader and scatter to boot such phones. - Added direct EMMI initialization for not Helio cpu, this will allow to handle directly phones with MT6535, MT6737, MT6580 cpu etc... -- This must solve problem with unknown or not added in database flash ic id, exe will dump it directly from phone. - Added checking for brom and preloader mode, using "bypass security" function. -- It will not allow booting in wrong mode. - Changed security Bypass payload's, will allow to dump more accurate preloader from phone. Supported cpu for bypass security with auto detection:
- Improved speed and stability for software testpoint function -- This function is important if need to use other tools like SP Flash tool and need to bypass phone security. Official Website: Avengers Box Download From Support Area Or Google Drive https://drive.google.com/file/d/1PRS...ew?usp=sharing Or MediaFire ****************************/file/a7w1l...0_7_8.rar/file Last edited by Fast Unlocking; 07-12-2021 at 15:42. |
The Following 24 Users Say Thank You to Fast Unlocking For This Useful Post: |
07-10-2021, 16:45 | #2 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | Code: Redmi 9 using "bypass security Flash files count is :25 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKDongle AndroidMTK 2.7.5 Scenario: [0]Safe Flash Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button until inserting USB cable. For some phones need to keep "VOL+ and VOL-" button until inserting USB cable. For some phones need to keep "VOL+" button until inserting USB cable. Detected(21) : MediaTek USB Port (COM21) [21] \\?\usb#vid_0e8d&pid_0003#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6768 CPU code: 707 Target config: e7 Secure boot enabled: true Need serial link authorization: true Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Received active handle reply from phone...... Booting phone Detected(21) : MediaTek USB Port (COM21) [21] \\?\usb#vid_0e8d&pid_0003#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6768 0 ca00 Using Algo 1. Helio MT6768 phone detected, swithing to helio api Loading emmi from download Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6768 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010044503644 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat operation. Detected(20) : MediaTek DA USB VCOM (Android) (COM20) [20] \\?\usb#vid_0e8d&pid_2001#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting flash Helio. [2] WRITE TO PARTITION [ recovery ] [7] WRITE TO PARTITION [ vbmeta ] [8] WRITE TO PARTITION [ vbmeta_system ] [9] WRITE TO PARTITION [ vbmeta_vendor ] [21] WRITE TO PARTITION [ efuse ] [24] WRITE TO PARTITION [ logo ] [25] WRITE TO PARTITION [ md1img ] [26] WRITE TO PARTITION [ spmfw ] [27] WRITE TO PARTITION [ scp1 ] [28] WRITE TO PARTITION [ scp2 ] [29] WRITE TO PARTITION [ sspm_1 ] [30] WRITE TO PARTITION [ sspm_2 ] [33] WRITE TO PARTITION [ lk ] [34] WRITE TO PARTITION [ lk2 ] [35] WRITE TO PARTITION [ boot ] [36] WRITE TO PARTITION [ dtbo ] [37] WRITE TO PARTITION [ tee1 ] [38] WRITE TO PARTITION [ tee2 ] [45] WRITE TO PARTITION [ super ] [46] WRITE TO PARTITION [ cache ] [47] WRITE TO PARTITION [ userdata ] HINT: If phone stuck on logo, for some phones help factory reset. Select factory reset tab/reset to factory default. [Helio]Wait until phone will start charging. [0]All done. |
The Following 8 Users Say Thank You to Fast Unlocking For This Useful Post: |
07-10-2021, 18:18 | #4 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Sambhal, India
Member: 2547744 Status: Offline Sonork: 1.1.1.1 Thanks Meter: 234 | Every Provider Uploads Their Latest Modules Links On Sites But Amazingly Avenger Team Uploads Single EXE On GDrive/MediaFire In Other Hand No Latest Tags In Server Even I'm Tring To Check What Updates So I Open Avengers Then Click On Support And There are lots of confusion what is latest Worst Team Ever. Kindly Support On Your Products And Get Tags On Latest Setups. |
The Following User Says Thank You to krrishxofficial For This Useful Post: |
07-10-2021, 18:55 | #6 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
This feature work from begining of avenger box. If you not know how to use box, it's your problem, not need to blame team for this Can you explain, where exactly is your confusion? | |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
07-10-2021, 23:55 | #12 (permalink) | |
Freak Poster Join Date: Feb 2016 Location: Caracas, Venezuela
Member: 2527159 Status: Offline Thanks Meter: 34 | Quote:
if i select download installers from Server it shows onli 2.9 version and from GD server is just 3.0 version. here you are showig 3.1 version but where can we download it? | |
07-11-2021, 01:47 | #14 (permalink) | |
https://forum.gsmhosting.com/vbb/f82...tware-2753994/ Latest version https://forum.gsmhosting.com/vbb/f82...020-a-2846268/ include support for top cards, but you can use as well 3.0 or 2.9 to acess support. | |
