Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > Avengers Box
Avengers Box (Multi Unlocker Box)
Old 07-10-2021, 16:43   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 90,971
Avengers Box / UMT Pro Android MTK Module v.0.7.8 Update Released [10/07/2021]
- Changed Bypass security function.
-- Now it become more fast, and take 2..3 sec in new exe version to bypass security.
- Enabled dump Preloader and EMMI initialization for not secure phones booted in Brom mode.
-- This feature allow to not use Preloader and scatter to boot such phones.
- Added direct EMMI initialization for not Helio cpu, this will allow to handle directly phones with MT6535, MT6737, MT6580 cpu etc...
-- This must solve problem with unknown or not added in database flash ic id, exe will dump it directly from phone.
- Added checking for brom and preloader mode, using "bypass security" function.
-- It will not allow booting in wrong mode.
- Changed security Bypass payload's, will allow to dump more accurate preloader from phone.
Supported cpu for bypass security with auto detection:
  • MT6735
  • MT6737
  • MT6580
  • MT6739
  • MT6755
  • MT6757
  • MT6763
  • MT6761
  • MT6765
  • MT6768
  • MT6771
  • MT6785
  • MT8127
  • MT8163
  • MT8173
  • MT8695
  • MT6873
  • MT6582
  • MT6799
- Improved speed and stability for software testpoint function
-- This function is important if need to use other tools like SP Flash tool and need to bypass phone security.
Official Website:
Avengers Box
Download From Support Area
Or
Google Drive
https://drive.google.com/file/d/1PRS...ew?usp=sharing
Or
MediaFire
https://www.mediafire.com/file/a7w1l...0_7_8.rar/file
The Following 24 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 07-10-2021, 16:45   #2 (permalink)
Member: 94675
Redmi 9 using "bypass security
Flash files count is :25
 Action : Firmware update.
 Selected Model: 0-By CPU: ELBRUS
 Exe version: NCKDongle AndroidMTK 2.7.5
 Scenario: [0]Safe Flash
 Phone must be off with battery inside.
 Battery must be charged
 Please connect phone in brom mode
 For some phones need to keep "VOL-" button until inserting USB cable.
 For some phones need to keep "VOL+ and VOL-" button until inserting USB cable.
 For some phones need to keep "VOL+" button until inserting USB cable.
 Detected(21) : MediaTek USB Port (COM21)
 [21] \\?\usb#vid_0e8d&pid_0003#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 CPU: MT6768 CPU code: 707 Target config: e7
 Secure boot enabled: true
 Need serial link authorization: true
 Need download agent authorization true
 Executing exploit, do not disconnect phone
 Exploit has been executed successfully.
 Dumping phone preloader.
 Waiting for handle to become active......
 Received active handle reply from phone......
 Booting phone
 Boot mode: Brom
 Phone detected...Please wait
 BBCHIP: 6768 0 ca00
 Using Algo 1.
 Helio MT6768 phone detected, swithing to helio api
 Loading emmi from download
 Helio enabled DRAM in First Da: FALSE
 Sending loader.....
 BBCHIP MT6768
 [1]Storage EMMC
 EMMC FW VERSION: 00:00:00:00:00:00:00:00
 EMMC CID: 15010044503644 : 000000000000000000
 EMMC UA SIZE: 0xe8f800000
 BOOT STYLE: EMMC BOOT
 FULL LENGTH: 0xe91000000      [58.266 GB]
 Status: USB_HIGH_SPEED
 Detecting high speed port, wait......
 If driver not installed, install high speed port driver.
 If not need high speed port, disable it.
 After repeat operation.
 Detected(20) : MediaTek DA USB VCOM (Android) (COM20)
 [20] \\?\usb#vid_0e8d&pid_2001#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Starting flash Helio.
  [2] WRITE TO PARTITION [ recovery ]
  [7] WRITE TO PARTITION [ vbmeta ]
  [8] WRITE TO PARTITION [ vbmeta_system ]
  [9] WRITE TO PARTITION [ vbmeta_vendor ]
  [21] WRITE TO PARTITION [ efuse ]
  [24] WRITE TO PARTITION [ logo ]
  [25] WRITE TO PARTITION [ md1img ]
  [26] WRITE TO PARTITION [ spmfw ]
  [27] WRITE TO PARTITION [ scp1 ]
  [28] WRITE TO PARTITION [ scp2 ]
  [29] WRITE TO PARTITION [ sspm_1 ]
  [30] WRITE TO PARTITION [ sspm_2 ]
  [33] WRITE TO PARTITION [ lk ]
  [34] WRITE TO PARTITION [ lk2 ]
  [35] WRITE TO PARTITION [ boot ]
  [36] WRITE TO PARTITION [ dtbo ]
  [37] WRITE TO PARTITION [ tee1 ]
  [38] WRITE TO PARTITION [ tee2 ]
  [45] WRITE TO PARTITION [ super ]
  [46] WRITE TO PARTITION [ cache ]
  [47] WRITE TO PARTITION [ userdata ]
 HINT:
 If phone stuck on logo, for some phones help factory reset.
 Select factory reset tab/reset to factory default.
 [Helio]Wait until phone will start charging.
 [0]All done.
The Following 8 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 07-10-2021, 18:05   #3 (permalink)
Member: 2145475
Thanks Meter: 99
Waoooo thanks its big update.........
Old 07-10-2021, 18:18   #4 (permalink)
krrishxofficial's Avatar
Member: 2547744
Sonork: 1.1.1.1
Thanks Meter: 157
Every Provider Uploads Their Latest Modules Links On Sites But Amazingly Avenger Team Uploads Single EXE On GDrive/MediaFire In Other Hand No Latest Tags In Server Even I'm Tring To Check What Updates So I Open Avengers Then Click On Support And There are lots of confusion what is latest Worst Team Ever. Kindly Support On Your Products And Get Tags On Latest Setups.
The Following User Says Thank You to krrishxofficial For This Useful Post:
Old 07-10-2021, 18:35   #5 (permalink)
Member: 2973928
Thanks Meter: 100
Great update team good work..
The Following User Says Thank You to blushis For This Useful Post:
Old 07-10-2021, 18:55   #6 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,556
You can use main module and acess support.
This feature work from begining of avenger box.
If you not know how to use box, it's your problem, not need to blame team for this
Can you explain, where exactly is your confusion?
The Following 2 Users Say Thank You to orbita For This Useful Post:
Old 07-10-2021, 19:04   #7 (permalink)
Member: 1905772
Thanks Meter: 4
Great team upgrade keep it up promises many better things in the future. The best NCK team
Old 07-10-2021, 19:05   #8 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 225
it's good now work faster on brom bypass (2-3 second)
Old 07-10-2021, 19:53   #9 (permalink)
somonahmed's Avatar
Member: 465069
Sonork: 100.1661026
Thanks Meter: 184
Qualcomm chip add new all models
The Following User Says Thank You to somonahmed For This Useful Post:
Old 07-10-2021, 20:19   #10 (permalink)
Member: 1395183
Thanks Meter: 2
buena actualizacion..gracias
Old 07-10-2021, 21:56   #11 (permalink)
Crazy Poster
Member: 2951507
Thanks Meter: 4
such a great effort looking more powerful and advanced based system for frp
Old 07-10-2021, 23:55   #12 (permalink)
Member: 2527159
Thanks Meter: 28
Where to find avengers main tool 3.1???
if i select download installers from Server it shows onli 2.9 version and from GD server is just 3.0 version. here you are showig 3.1 version but where can we download it?
Old 07-11-2021, 00:54   #13 (permalink)
Member: 1717416
Sonork: 100.1675419
Thanks Meter: 29
Nice update...... Without costing any money.
Old 07-11-2021, 01:47   #14 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,556
Direct link for main module.
https://forum.gsmhosting.com/vbb/f82...tware-2753994/
Latest version https://forum.gsmhosting.com/vbb/f82...020-a-2846268/
include support for top cards, but you can use as well 3.0 or 2.9 to acess support.
Old 07-11-2021, 04:52   #15 (permalink)
Member: 2603633
Sonork: family
Thanks Meter: 192
Avengers team best in the world.....
The Following User Says Thank You to haseebkakar For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.19875 seconds with 8 queries
