Avengers Box (Multi Unlocker Box) |
07-14-2021, 18:45 | #31 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Selecting this cpu from list, exe will use more old da, what is compatible with this cpu. If you not like to select cpu from list, you can load compatible da manually. Many phones like nokia, vivo, oppo and other brands, will not connect anymore in preloader mode. But this is not exe fault, in phone firmware was changed connection mode, and not exists this option anymore. Not understand where exactly is your problem here, and what you lost if phone will connect in brom mode, not in preloader mode. Last edited by orbita; 07-14-2021 at 18:50. | |
08-02-2021, 09:51 | #37 (permalink) |
Crazy Poster Join Date: Mar 2018 Location: Mozambique
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | Nck dongle Problema no Dump Firmware cpu Movitel M8421 Mtk 6580) pais, africa Action : Read Firmware. Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.8 Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek PreLoader USB VCOM (Android) (COM4) [4] \\?\usb#vid_0e8d&pid_2000#6&3703ea33&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (57Gb+8192Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: D60103303841333931 : 00000000000000 EMMC UA SIZE: 0x1ce400000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1cf000000 [7.234 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(6) : MediaTek DA USB VCOM (Android) (COM6) [6] \\?\usb#vid_0e8d&pid_2001#6&3703ea33&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Build Date: Wed Jul 29 17:48:30 CST 2020 Build ID: QP1A.190711.020 Version: 10 Mediatek Version Release: 10 Brand: Movitel Device: M8421 Manufacturer: Movitel Model: M8421 Phone have OTP partition. IMEI[1]: 35xxxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxxx Start dumping flash, this can take up to 1 hour....... Dumping Preloader. Partition: proinfo Partition: nvram Partition: protect1 Partition: protect2 Partition: persist Partition: seccfg Partition: lk Partition: lk2 Partition: boot Partition: recovery Partition: para Partition: logo Partition: dtbo Partition: vbmeta Partition: vbmeta_system Partition: vbmeta_vendor Partition: expdb Partition: frp Partition: tee1 Partition: tee2 Partition: nvdata Partition: md_udc Partition: metadata Partition: oemkeystore Partition: secro Partition: keystore Partition: super Partition: cache Partition: userdata Partition: otp Partition: flashinfo Start processing proinfo.bin ...... Reading: BEGIN: 0x80000 - LEN: 0x300000 Start processing nvram.bin ...... Reading: BEGIN: 0x380000 - LEN: 0x500000 Start processing protect1.img ...... Reading: BEGIN: 0x880000 - LEN: 0xa00000 Start processing protect2.img ...... Reading: BEGIN: 0x1280000 - LEN: 0xa00000 Start processing persist.img ...... Reading: BEGIN: 0x1c80000 - LEN: 0x3000000 Start processing lk lk.img Start processing boot boot.img Reading: BEGIN: 0x4dc0000 - LEN: 0x1000000 Start processing recovery recovery.img Reading: BEGIN: 0x5dc0000 - LEN: 0x1000000 Start processing logo logo.bin Start processing dtbo dtbo.img Reading: BEGIN: 0x7640000 - LEN: 0x800000 Start processing vbmeta vbmeta.img Start processing vbmeta_system vbmeta_system.img Start processing vbmeta_vendor vbmeta_vendor.img Start processing tee1 tee.img Start processing nvdata.img ...... Reading: BEGIN: 0xab40000 - LEN: 0x2000000 Start processing md_udc md_udc.img Reading: BEGIN: 0xcb40000 - LEN: 0x169a000 Start processing secro secro.img Reading: BEGIN: 0x10a00000 - LEN: 0x600000 Start processing super super.img Reading: BEGIN: 0x11800000 - LEN: 0x80000000 [4009]ReadbackPartitionToBuffer fail!: S_FT_READBACK_FAIL Start processing cache cache.img Start processing userdata userdata.img (good technician and programmer mr Orbita, this phone when I dump firmware it runs fine when it gets to the stage, userdate for no 56% this information comes out .....) Last edited by joaquimpanete; 08-02-2021 at 09:56. Reason: mal excrito |
08-02-2021, 10:29 | #38 (permalink) | |
UFF, even not know from where to start. First, this cpu MT6580 is not helio cpu, so you can't write readed backup. Phones with this cpu will accept only signed factory firmware. Second, all android phones, starting from android 5.1 have encripted userdata. In this case, you can't write back readed backup, even in same phone. This option remain in exe for old phones , or phones what have disabled by user userdata encription(need to root phone and modifiy buid.prop) e.t.c. In all other cases, if you not know exactly why you dump userdata, this option must be unchecked. Next, if exe give error on read, here can be 2 problems,discharged battery or problem with flash ic. Phones with helio cpu, allow to boot even without battery, but this one(mt6580) not. Some like this, hopping my answer will help you. | |
The Following User Says Thank You to orbita For This Useful Post: |
08-02-2021, 14:32 | #39 (permalink) |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | nck dongle Hurricane Excite Action : Read Firmware. Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.8 Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(8) : MediaTek PreLoader USB VCOM_V1633 (Android) (COM8) [8] \\?\usb#vid_0e8d&pid_2000#6&61482&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (117Gb+8192Mb) SANDISK 0x444634303136 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 450100444634303136 : 00000000000000 EMMC UA SIZE: 0x3ab400000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac000000 [14.688 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(10) : MediaTek DA USB VCOM (Android) (COM10) [10] \\?\usb#vid_0e8d&pid_2001#6&61482&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Build ID: O11019 Display ID: Hurricane_Excite_V02_20200303 Version: 8.1.0 Model: Excite Brand: Hurricane Device: Excite Manufacturer: Hurricane IMEI[1]: 35xxxxxxxxxxxxx IMEI[2]: 35xxxxxxxxxxxxx Start dumping flash, this can take up to 1 hour....... Dumping Preloader. Partition: proinfo Partition: nvram Partition: protect1 Partition: protect2 Partition: seccfg Partition: lk Partition: lk2 Partition: boot Partition: recovery Partition: para Partition: logo Partition: odmdtbo Partition: expdb Partition: vendor Partition: frp Partition: tee1 Partition: tee2 Partition: nvdata Partition: metadata Partition: oemkeystore Partition: secro Partition: keystore Partition: system Partition: cache Partition: userdata Partition: flashinfo Start processing proinfo.bin ...... Reading: BEGIN: 0x80000 - LEN: 0x300000 Start processing nvram.bin ...... Reading: BEGIN: 0x380000 - LEN: 0x500000 Start processing protect1.img ...... Reading: BEGIN: 0x880000 - LEN: 0xa00000 Start processing protect2.img ...... Reading: BEGIN: 0x1280000 - LEN: 0xa00000 Start processing lk lk.img Start processing boot boot.img Reading boot.img Start processing recovery recovery.img Reading recovery.img Start processing logo logo.bin Start processing odmdtbo odmdtbo.img Start processing vendor vendor.img Reading: BEGIN: 0x6000000 - LEN: 0x12000000 Start processing tee1 tee.img Start processing nvdata.img ...... Reading: BEGIN: 0x18b00000 - LEN: 0x2000000 Start processing secro secro.img Reading: BEGIN: 0x1d200000 - LEN: 0x600000 Start processing system system.img Reading: BEGIN: 0x1e000000 - LEN: 0x5c800000 Start processing cache cache.img Start processing userdata userdata.img Saved to : C:\ProgramData\Android_MTK_Backup_Folder\firmware_ backup\MT6580_EMMC_Excite_Hurricane__2021_08_02_15 _16 Wait untill phone will start charging. [0]All done. |
10-06-2021, 14:48 | #40 (permalink) |
Junior Member Join Date: Jan 2020 Location: Maxixe
Member: 2945769 Status: Offline Sonork: http://forum.gsmhosting.c Thanks Meter: 32 | Huawei AMN-LX9 FRP Done in Test point Exe version: Avengers Box MTK 0.7.8 Selected model: Huawei AMN-LX9 [auto]Action: Reset FRP Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&30f0d3dd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Loading emmi from database Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6761 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68423861 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Modem version: MOLY.LR12A.R2.TC3.UNI.PR3.SP.V1.P27 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to Chissaservices For This Useful Post: |
