Avengers Box (Multi Unlocker Box) |
10-18-2021, 06:45 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,880 | Avengers Box / UMT PRO Android MTK Module v0.7.9 Released - 18/10/2021] - Added Unlock & Lock BOOTLOADER for Helio cpu. -- Tested MT6761, MT6763, MT6765, MT6768 cpu (PPlease Test More CPU & Report). -- Software will check phone Algo, and will not allow to use this function if phone not supported. - Added SAFE RESET FOR OPPO Phones in flash mode. -- Need to tick "bypass security" checkbox to use this feature. - Added SAFE RESET FOR VIVO Phones in flash mode. -- Need to tick "bypass security" checkbox to use this feature. - NEW - Added support for UFS Filesystem, for supported phones. Now supports All Functions related to UFS filesystem supported phones. - Added functions for the following models
Oukitel
- Updated bypass security function for supported cpu's. Supported cpu for this function:
- Improved save Preloader function for supported CPU, exe will bypass security and will dump Preloader at same time. -- After will be used this Preloader to fill EMMI setting and boot phone. --- Phone must be functional to use this function, in case of damaged firmware, will need to use external Preloader to boot phone. - Updated(fixed) generic reset in flash mode. -- Need to tick "bypass security" checkbox to use this feature. - Disabled switch to meta with bypass security enabled. -- This function was designed for use in flash mode, and it not allow to boot phone in meta. --- Many users report not working meta mode because of this. Official Website: Avengers Box NCK PRO Website: www.nck-pro.com Download From Support OR GDrive https://drive.google.com/file/d/1l5z...ew?usp=sharing OR Mega https://mega.nz/file/4M5C2D4S#0ijcQd...mbfAyHGYqW2Gbg Last edited by Fast Unlocking; 10-18-2021 at 07:07. |
The Following 20 Users Say Thank You to Fast Unlocking For This Useful Post: |
10-18-2021, 07:21 | #3 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,880 | Code: Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(6) : MediaTek USB Port (COM6) [6] \\?\usb#vid_0e8d&pid_0003#6&35c31b9d&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6761 CPU code: 717 Target config: e1 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: false SWJTAG enabled: false EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Executing selected by user payload Exploit has been executed successfully. [3b600]Dumping phone preloader. Preloader: F:\android_mtk_backup\Android_MTK_Backup_Folder\preloader_backup\preloader_wasp.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(6) : MediaTek USB Port (COM6) [6] \\?\usb#vid_0e8d&pid_0003#6&35c31b9d&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6761 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 88010344394431 : 000000000000000000 EMMC UA SIZE: 0x39d000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x39dc00000 [14.465 GB] Checking data, wait... Phone bootloader state: Locked Unlocking bootloader.... Done. [helio]Wait untill phone will start charging. [0]All done. |
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post: |
10-18-2021, 11:51 | #9 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Morocco
Member: 1712203 Status: Offline Thanks Meter: 356 | Oppo A5s test : info : can you add more information about phone when you do reset like model version build and thanks for hard work |
The Following User Says Thank You to apologized For This Useful Post: |
10-18-2021, 12:01 | #10 (permalink) |
Insane Poster Join Date: Oct 2016 Location: Chile
Member: 2637184 Status: Offline Sonork: www.google.com Thanks Meter: 72 | add read partition table. that option is very important and is the only thing missing. |
The Following 2 Users Say Thank You to angelh666 For This Useful Post: |
10-18-2021, 14:23 | #12 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | The file you are trying to download is no longer available. This link is unavailable as the user’s account has been closed for gross violation of MEGA’s Terms of Service. |
10-18-2021, 14:23 | #13 (permalink) |
Member: 1984825 Status: Offline Thanks Meter: 222 | error file The file you are trying to download is no longer available. This link is unavailable as the user’s account has been closed for gross violation of MEGA’s Terms of Service. |
10-18-2021, 14:40 | #15 (permalink) | |
Member: 1712203 Status: Offline Thanks Meter: 356 | Infinix Hot 10 Play (X688B) unlock bootloader Quote:
