Avengers Box (Multi Unlocker Box) |
01-17-2021, 08:52 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,240 | Avengers Box / UMT Pro SPRD Module v1.4 Update Released - [17/01/2021] Added: Lava Atom 2X - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LE9920 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LH9810 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LH9910 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LN9820 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LN9821 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). X11 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). X41 Plus - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Z40 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Z51 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Alcatel OT-3080 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). OT-3088 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Supported/Added for direct selection in exe next cpu
If generic loader not work (this can happen in new phones if loader sign key differ), user must use custom loader generated from pac firmware. - Added phrasing for DHTB header on new CPU, this will allow to display more detailed info about cpu. - Added fastboot functions in exe. - Added unlock bootloader in fastboot mode new generation cpu. This method is based on leaked rsa key and support many phones. But will not work for all phones, if phone firmware have different sign key, metod will not work. 1. Read info(token id) 2. Generate signature file using leaked rsa4096_vbmeta.pem key(need_files directory) On this step user will select private key, and exe will prompt to default one. Can be selected other private key if user have it and it's supported by phone 3. Sending generated signature in phone. On some models this function will work, on some not(key differ) If your phone not accept generated by exe signature, user can request this file officially and send in phone using exe. Exe allow to select key file, if user have private key from firmware source, he can use own key. Tested on alcatel ot-5024, Xiaomi Qin 2, posible will work in other phones. -- Locked Bootloader. --- Erase FRP in fastboot mode(need unlocked bootloader) - Added support for new pac format (old exe gived exception on this) Exe will autodetect pac format and will use new or old layout auto. - Added simunlock in flash mode for supported phones. Many phones after unlock in diag mode relock after factory reset, so this will help to solve problem. - Added simunlock support for phones with new security, so called type 4 This is beta version, if some not work, will need to provide nvram backup maked by this exe version. Backups maked by old exe versions is not compatible with this. Unlock is supported in diag mode and flash mode. Unlock will work only on phones with not damaged security. Phones with erased or rewrited from other phone nvram will not work. Website: Avengers Box Download From Support Area OR MediaFire ****************************/file/y296v...fixed.rar/file Google Drive https://drive.google.com/file/d/1Hac...ew?usp=sharing |
The Following 27 Users Say Thank You to Fast Unlocking For This Useful Post: |
01-17-2021, 12:54 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | World 1st zte kicka 4 ve free unlock done wow great HERE LOG |
The Following 11 Users Say Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
01-18-2021, 08:04 | #15 (permalink) |
Freak Poster Join Date: Nov 2019 Location: South Africa Age: 33
Member: 2934673 Status: Offline Sonork: Still Not Created Thanks Meter: 218 | ZTE L130 kicka 4 ve unlock done without credit This phone have frp partition. MatchesMask [w_fixnv1] [w_fixnv1] Size to download: 1024 KB Reading w_fixnv1 IMEI 1: 861486041019612 IMEI 2: 867400020316620 Simlock Type: 4 Simlock Status: SIMLOCK: INACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 Backup saved to: C:\Users\gsm africa\Documents\spreadtrum_module\simlock_flashmo de_backup_nvram\VDC_ZA_L130_V1.1\VDC_ZA_L130_V1.1_ nvram_backup.tar Unlock is supported for this phone Integrity seems ok, proceed with unlock.... Start write unlock, wait... Wait untill phone restart. Log saved: C:\Users\gsm africa\Documents\spreadtrum_module\Saved_Logs\sc77 31e_1h20_v1.1.0SC7731e_2_IRD_K_V1.1.0VDC_ZA_L130_V 1.1_861486041019612_867400020316620_sim_unlock_pho ne.txt Total Time: 00:00:33 Done. |
The Following 4 Users Say Thank You to GSM.AFRICA For This Useful Post: |
