Avengers Box (Multi Unlocker Box) |
08-16-2021, 17:02 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This is secured phone, and will not run on generic model selection. You must boot your phone corectly, or use bypass security function. |
08-17-2021, 07:42 | #5 (permalink) |
Crazy Poster Join Date: Mar 2018 Location: Mozambique
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | in the security function bapass the information logs shows that neither a virus nor can it be read I have already sent you an image of tecno pop4 with the same information as a virus |
08-17-2021, 07:44 | #6 (permalink) | |
Member: 2825965 Status: Offline Sonork: 846072805 ou 869337492 Thanks Meter: 5 | Quote:
? 3K =? Ú – âxþ) ©] í ‡ ÂU3Å?: ^ Â? ÀŠs “Z © <- n?,? Ç? ÉÀ °? ‡ Ç • oªb0? © bžX? ¤ * KKû§ # ?? Œ ? úè <yéž · ›? A« Œ “¸XŽA]? ê ™‹ ÉÃoŸÄÉU? © uË8þ ????? ™ éšZtÎäù ??? ã? Ÿ »¤Îç? JÃœ :? ?? ´ ?? É? ª? Æ? Ö ©? ± ÃÌ ??? Ø * Jy ?? © Cü ?? §q ›v? U • –Ó © § ¢? ÙçìÿûƒU € v £ Pøté8þµäööùÌø $ # ^ å € ~ FÞ ?? ³ ‹§É²ÐN ‡ ¢ ª_» i3áÊå1î– ›¹G?” Pô? ÀMj‚û6 · _ × žŠý = ®2zO ?? „®JvAÃè ??‚ éòò åE? Íä¼ø ?? ^. Féc ^ Ùéy¼ ”?? é¬ ?? a ??? HÐ`? ¼ Yšéæ £ N“ 鯧? Å? È <% ãéÈ` ^ Ãk? Y »è¶»? ƪslpÊ? <ØJ •} _? 9 ¢ ùn ? Ï Œ¤âIšGÒ, oo \ ¾Lò½ ?? ħ {PID_0003 | |
08-17-2021, 12:49 | #7 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Will try to guess, exe told you to connect phone in brom mode, but you powered phone in preloader mode? Or you not have installed libusb filter? Or you use wrong, incompatible da. Or you not have installed drivers. Or....no idea, without log is imposible to guess. This phone you can service in preloader mode also, without any security bypass, just using correct da, or use securioty bypass(corectly) and select generic model. | |
The Following User Says Thank You to orbita For This Useful Post: |
08-17-2021, 15:09 | #8 (permalink) | |
