Avengers Box (Multi Unlocker Box) |
03-30-2022, 10:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: gsmforum
Member: 2118052 Status: Offline Thanks Meter: 565 | cph1861 realme 1 connecting error.. Selected OPPO:Realme 1(CPH1861) Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(7) : MediaTek USB Port_V1632 (COM7) [7] \\?\usb#vid_0e8d&pid_0003#5&799f7a8&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6771 CPU code: 788 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. Error dumping preloader, please use external preloader to boot phone. Waiting for handle to become active...... Reseived active handle repply from phone...... here exe hanged boot bypass security is not working too. if bypss boot security with third party tool and select cpu manually then succes Action : Boot Info. Selected 0-By CPU:MT6771 Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(7) : MediaTek USB Port_V1632 (COM7) [7] \\?\usb#vid_0e8d&pid_0003#5&799f7a8&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6771 0 ca00 Using Algo 1. Helio MT6771 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6771 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010047443642 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x748800000 [29.133 GB] Build ID: O11019 Version: 8.1.0 Manufacturer: OPPO This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R2.TC16.SP.V33 [helio]Wait untill phone will start charging. [0]All done. the same error in umt too pls fix its |
