Avengers Box (Multi Unlocker Box) |
11-22-2020, 15:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Itell A33 no signal after privacy lock remove EXE: Avengers Spreadtrum Module 1.3 SELECTED: A33(W5001) ACTION: Restore factory nvram Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM35) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. Manufacturer: itel Hardware: sc7731e_1h10_v1.1.0 Hardware version: SC7731e_2_IRD_K_V1.1.0 Build product name: F3102 Build description: W5001P-user 8.1.0 OPM2.171019.012 412 release-keys Product name: F3102 Transsion device name: itel A33 Build Id: OPM2.171019.012 Model: itel W5001P Android Release: 8.1.0 Android Version: W5001P-F3102-8.1-OP-V068-20201013 Security patch: 2020-10-05 This phone have frp partition. MatchesMask [w_fixnv1] [w_fixnv1] Size to download: 1024 KB Reading w_fixnv1 IMEI 1: 358481109093740 IMEI 2: 358481109093757 Simlock Type: 4 Protecting IMEI_1 id: 0x5 len: 0x8 Protecting IMEI_2 id: 0x179 len: 0x8 Protecting BlueTooth id: 0x191 len: 0x8 Protecting BandSelect id: 0xD len: 0x1 Protecting WIFI id: 0x199 len: 0x14 Protecting SIMLOCK_SIGN id: 0x1A3 len: 0x280 Protecting SIMLOCK_PK id: 0x1A4 len: 0x228 Protecting SIMLOCK_CUSTOMIZE_DATA id: 0x1F0 len: 0xF5C Protecting SIMLOCK_USER_DATA id: 0x1F1 len: 0x4D4 Protecting SIMLOCK_NVCONTROL_KEY id: 0x1F2 len: 0x1A0 Protecting SIMLOCK_KEY id: 0x1F4 len: 0xA0 Protecting SIMLOCK_CFG id: 0x7E4 len: 0x2B Restoring done Restoring done Wait untill phone restart. Log saved: C:\Users\Talat Hussain Dar\Documents\spreadtrum_module\Saved_Logs\_358481 109093740_358481109093757_RestoreNvramFactoryPriva cy.txt Total Time: 00:00:17 Done. |
11-22-2020, 15:37 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Usually this have nothing to do with signal, posible exists other problems. Perform wipe after privacy reset. If this not help, simple restore nv backup as exe warn you when you push privacy button. |
The Following User Says Thank You to orbita For This Useful Post: |
11-22-2020, 16:17 | #3 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Thanks for fast answer problem was that model was w5001P and i select w5001, now i find "Repair Factory NVRM" opiton under w5001p model and it works and phone is working fine.... Thanks |
The Following User Says Thank You to darmobiles For This Useful Post: |
11-22-2020, 16:23 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This is important, models contain inside some specific setting what is not compatible between. You not specify wrong model selection in your post, so was imposible to guess it. |
The Following 3 Users Say Thank You to orbita For This Useful Post: |
