Avengers Box (Multi Unlocker Box) |
11-06-2020, 05:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | jazz digit 4g new security not supported need solution kindly correct me if im doing something wrong read firmware logs preloader mode Action : Read Firmware. Selected Jazz:Jazz Digit 4G Exe version: Avengers Box MTK 0.7.4 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM4) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6739 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. read firmware bootroom mode Action : Read Firmware. Selected Jazz:Jazz Digit 4G Exe version: Avengers Box MTK 0.7.4 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM3) Boot mode: Brom Brom stage DA fail, aborting [STATUS_SEC_AUTH_FILE_NEEDED][AUTH]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model Or load auth file manually in exe Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. unlock in meta mode logs Exe version: Avengers Box MTK 0.7.4 Selected model: Jazz Jazz Digit 4G Action: Unlock Scanning for presents meta ports... Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL+ and VOL-" or "VOL-" button untill inserting USB cable. [4]Detected: MediaTek PreLoader USB VCOM (Android) (COM4) \\?\usb#vid_0e8d&pid_2000#6&1ba46697&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [6]META Port Detected: MediaTek USB VCOM (Android) (COM6) USB\VID_0E8D&PID_2007\6&1BA46697&0&7 ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 Start sync target, waiting responce..... [META]BaseBand CPU : MT6739 [META]SW_VER : MOLY.LR12A.R3.MP.V62.P9 [META]HW_VER : FISE6731_KAIS_S_E_K_HW [helio]Read simlock info. IMEI Location: NVRAM Phone imei[1] : 354xxxxxxxxxxxx Phone imei[2] : 3547xxxxxxxx Start direct unlock[SIM1] Simlock checksum is ok. Simlock data not found(2). Start direct unlock[SIM2] Simlock checksum is ok. Simlock data not found(2). Simlock checksum is ok. Simlock data not found(2). Simlock checksum is ok. Simlock data not found(2). [helio]Wait untill phone will start charging. [0]All done. read info in meta mode Action : Meta Info. Selected Model: Jazz:Jazz Digit 4G Exe version: Avengers Box MTK 0.7.4 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [4]Detected: MediaTek PreLoader USB VCOM (Android) (COM4) \\?\usb#vid_0e8d&pid_2000#6&1ba46697&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [6]META Port Detected: MediaTek USB VCOM (Android) (COM6) USB\VID_0E8D&PID_2007\6&1BA46697&0&7 Start sync target, waiting responce..... ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 Brand: alps Model: Digit4G Name: Digit4G Device: Digit4G Release: Digit_M42421DG_EF2_SW02_20200917_1932 Version: 4.4.2 Mediatek Version: alps-mp-k0.kaios.mp2-V1.6_P19 Branch: alps-mp-k0.kaios.mp2 Platform: MT6739 [MT6739]Using Algo 5 SIM Count: 2 [0]Starting META using port[COM6], wait... BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R3.MP.V62.P9 MODEM HW Version : FISE6731_KAIS_S_E_K_HW IMEI location: FAT IMEI[1] : 354xxxxxxxxxxx IMEI[2] : 354xxxxxx BarCode: JTDJ00200924170807000825 P 10P [helio]Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to Arslanmayo For This Useful Post: |
11-06-2020, 14:04 | #2 (permalink) | |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | Quote:
Downgrade Firmware available at support area Please Check | |
11-06-2020, 15:47 | #3 (permalink) | |
Member: 2478233 Status: Offline Thanks Meter: 596 | Quote:
i unlocked almost 50 pieces with avenger by downgrading but this one is different mean new model with new security | |
11-09-2020, 03:56 | #7 (permalink) |
Freak Poster Join Date: Apr 2011 Location: pk
Member: 1565811 Status: Offline Sonork: 786 Thanks Meter: 8 | ver 200916v1 fix this ver Flash files count is :15 Action : Firmware update. Selected Model: Jazz: Jazz Digit 4G Exe version: Avengers Box MTK 0.7.4 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM11) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6739 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. |
11-10-2020, 16:19 | #10 (permalink) | |
11-20-2020, 08:16 | #11 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port_V1632 (COM6) Boot mode: Brom Brom stage DA fail, aborting [STATUS_SEC_AUTH_FILE_NEEDED][AUTH]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model Or load auth file manually in exe Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. new security add da file needed |
11-20-2020, 09:24 | #12 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am not have this phone and here is not posible to find it. So for now not posible to make any solution. When will be posible, we will make public update. Closed. |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
