Avengers Box (Multi Unlocker Box) |
02-24-2022, 12:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | mi 9T flashing error Operation: Upgrade Searching for phone..... Qualcomm HS-USB QDLoader 9008 (COM33) detected. Hello received. HW ID: 00007200E1600E00 PK HASH: 1BEBE3863A6781DB4B01086063007334DE9E5CA14971C7C4F4 358EC9D79CDA46 Using custom loader: prog_ufs_firehose_sdm855_ddr.elf Arhitecture:64 bits [64]Sending loader, please wait.. Readed length: 16 Waiting for loader to start... ComportMessage: WriteFile function failed WinMessage: System Error. Code: 995. The I/O operation has been aborted because of either a thread exit or an application request |
02-24-2022, 12:47 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,957 | Need to check your usb cable, usb port, connection or phone hardware. This error meen, exe can't comunicate with phone. Code: ComportMessage: WriteFile function failed WinMessage: System Error. Code: 995. |
02-24-2022, 13:18 | #4 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,957 | Quote:
EDL testpoint must be performed without battery. I'am usually disconnect battery, solder 2 wires to testpoint, connect together wires, insert cable, and after disconnect wires. When phone will enter in edl state, opened exe will show opened port in status bar. This mettod allow to not make any hardware damages in phone by mistake. In your case is more like hardware problem with phone or connection problem. | |
02-27-2022, 19:15 | #7 (permalink) | |
Phone can't initialise loader, Loader start in ram, after starting loader, loader make hardware initialisation, and flash ic initialization. In your case, phone give error on starting loader, and this can meen hardware problems. It have nothing to do with erased firmware, check once again phone hardware. | |
