Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > Avengers Box
Avengers Box (Multi Unlocker Box)
Old 08-01-2018, 08:44   #1 (permalink)
nf6_tony's Avatar
Member: 694443
Thanks Meter: 64
oppo A83
I'm using UMT pro dongle, oppo A83 password not done...
Old 08-01-2018, 08:45   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
where is logs/screenshot ?
Old 08-01-2018, 08:50   #3 (permalink)
nf6_tony's Avatar
Member: 694443
Thanks Meter: 64
https://www.4shared.com/photo/rJuuOhaRda/avengers.html?
Old 08-01-2018, 08:52   #4 (permalink)
Member: 2211790
Thanks Meter: 5,118
try once with select oppo F5
possible bug in this version
can try with previous version
also once re-power set before try (on it then off)
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 08-01-2018, 09:07   #5 (permalink)
nf6_tony's Avatar
Member: 694443
Thanks Meter: 64
same error both 0.5.2 and 0.5.3 versions
Old 08-01-2018, 09:16   #6 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
This is not related to exe, is related to phone.
Posible different firmware version or oppo fixed some.
We tested on 2 A83 phones and was ok.
One user already reported this, will need to check exactly where is problem, posible incompatible DA loader(oppo use other da for this phone in latest version) or is implemented authentification like for A71 qualcomm.
Anyway, right now can't tell more.
The Following 2 Users Say Thank You to orbita For This Useful Post:
Old 08-01-2018, 13:14   #7 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
Hi Bro,Check for test report Working fine,
Boot Keep VOL- button untill inserting USB cable.
http://forum.gsmhosting.com/vbb/f820...ngers-2433258/
Old 08-01-2018, 13:30   #8 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
Boot Key hold the VOLUME DOWN key
Boot info
Meta info
Wipe User Data
FRP Reset
The Following User Says Thank You to kabul For This Useful Post:
Old 08-02-2018, 02:30   #9 (permalink)
Member: 2211790
Thanks Meter: 5,118
@kabul bro
Possible user not following right procedure or can be new version with fixed by oppo as Orbita bro said...
Also i can't check my nck already expired..
Old 08-02-2018, 06:35   #10 (permalink)
nf6_tony's Avatar
Member: 694443
Thanks Meter: 64
I followed the instructions, I search before I post...but If you read the reply of Sir Orbita, DA problem...
Old 08-02-2018, 07:55   #11 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Try to make meta info, let's see if exists difference between phones.
Old 08-02-2018, 08:28   #12 (permalink)
nf6_tony's Avatar
Member: 694443
Thanks Meter: 64
sorry, not possible this time...already taken by the owner...
Page generated in 0.17530 seconds with 8 queries
