Avengers Box (Multi Unlocker Box) |
02-19-2018, 12:22 | #691 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | One Touch OT5020A Unlocked Successfully Code: Action : Boot Info. Selected Alcatel:OT-5020 Exe version: Avengers Box MTK 0.4.9 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM81) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6575 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Build ID: JRO03C Display ID: Jelly Bean Version: 4.1.1 Build Date: Tue Jan 28 14:23:37 CST 2014 Model: ALCATEL ONE TOUCH 5020A Brand: TCT Device: Megane_GSM Region: AU Mediatek Version Release: ALPS.JB.MP.V1 MODEL FROM PROINFO: 5020A-2BVDAU1 SECRO FROM PROINFO: X2A0OV03AB00 OTP IMEI: 013511008157183 Wait untill phone will start charging. All done. Code: Selected connection metod: FLASH Mode Exe version: Avengers Box MTK 0.4.9 Selected model: OT-5020 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM81) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6575 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED OTP IMEI : 013511008157183 Reading security, wait... SECRO FW : X2A0OV03AB00 NCK: 22340283 : Locked NSCK: 34805484 : Unlocked SPCK: 27238459 : Unlocked SIM: 16133995 : Unlocked If lock counter is 0, make "Format UserData" from exe. Simlock saved to : C:\Avengers\android_mtk\simlock_backup\_X2A0OV03AB00_backup.nsb Wait untill phone will start charging. All done. |
The Following 4 Users Say Thank You to EjazATF For This Useful Post: |
02-20-2018, 10:15 | #692 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | OPPO R1001 V2 - Hang on logo problem has been solved using avengers safe flashing method, update/flash using card option was showing error while updating Code: Flash files count is :21 Action : Firmware update. Selected Model: 0-By CPU: MT6571_EMMC Exe version: Avengers Box MTK 0.4.9 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM114) Boot mode: Brom Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Preloader SEC version: 2 Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM116) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
02-20-2018, 11:09 | #693 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | QMobile Evok Power 7.0 - FRP Removed Successfully Code: Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM81) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x513331334d42 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 15010051333133 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED -Reading GPT Drive OK Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
02-21-2018, 14:07 | #695 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | OPPO R9s Plus, Boot Info + Factory Reset + FRP Removal Success Code: Operation: Read Info Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1009900 MSM8976 PK HASH: 3BE970A8579CAC806528AEEDD3A88C72EEAF41E0B4FCDF01BF68420C54E7584C Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 58.24 GB Partitions count: 56 Userdata Size: 53.28 GB Manufacturer: OPPO Cpu: arm64-v8a Build Id: MMB29M Model: CPH1611 Android Release: 6.0.1 Android Version: CPH1611EX_11_A.13_170715 Security patch: 2017-07-01 Restarting phone..... ************************************* Code: Operation: Factory Format Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1009900 MSM8976 PK HASH: 3BE970A8579CAC806528AEEDD3A88C72EEAF41E0B4FCDF01BF68420C54E7584C Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 58.24 GB Partitions count: 56 Userdata Size: 53.28 GB Manufacturer: OPPO Cpu: arm64-v8a Build Id: MMB29M Model: CPH1611 Android Release: 6.0.1 Android Version: CPH1611EX_11_A.13_170715 Security patch: 2017-07-01 Resetting cache , wait Total blocks 15 Resetting userdata , wait Total blocks 900 Factory reset done, wait untill phone start This can take up to 5 min on slow phones. Restarting phone..... ************************************* Code: Operation: Reset FRP Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1009900 MSM8976 PK HASH: 3BE970A8579CAC806528AEEDD3A88C72EEAF41E0B4FCDF01BF68420C54E7584C Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 58.24 GB Partitions count: 56 Userdata Size: 53.28 GB Erasing FRP, wait..... Erasing FRP, finished Restarting phone..... ************************************* |
02-21-2018, 14:16 | #696 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Oppo a37f hang on logo done by factory reset. Operation: Factory Format Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1507000 MSM8916 PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F Checking database for suitable loader..... Arhitecture:32 bits Storage:EMMC Sending loader, please wait.. Waiting for loader to start... Reading partition info, wait. Volume[0] Size: 14.68 GB Partitions count: 38 Userdata Size: 11.14 GB Manufacturer: OPPO Cpu: arm64-v8a Build Id: LMY47V Model: A37f Android Release: 5.1.1 Android Version: A37fEX_11_171008 Config: diag,serial_smd,rmnet_bam,adb Security patch: 2017-09-01 Resetting userdata , wait Total blocks 217 Resetting cache , wait Total blocks 10 Factory reset done, wait untill phone start This can take up to 5 min on slow phones. Restarting phone..... |
The Following User Says Thank You to mobile mart For This Useful Post: |
02-26-2018, 10:35 | #698 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 313684 Status: Offline Thanks Meter: 35 | Motorola Droir frp remove don with umt Port : Fastboot Inteface Baud Rate : Not Applicable Device : Motorola Operation : New FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1254 Boot Ver. : moto-apq8084-70.96 Baseband : MDM9625_41.51.07.22.04R QUARK_CUST Software : Blur_Version.24.91.5.quark_verizon.verizon.en.US IMEI : 990005116153249 CPU : APQ8084 ES1.1 RAM : 3072MB Samsung S8 SDRAM DIE=6Gb EMMC : 64GB Hynix REV=07 PRV=03 TYPE=57 Setting Factory Mode... OK Searching Network Interface... Found Connecting to device... OK Model : XT1254 Bootloader : 0x7096 Baseband : MDM9625_41.51.07.22.04R QUARK_CUST Build : Blur_Version.24.91.5.quark_verizon.verizon.en.US Android : 6.0.1 Searching Network Interface... Found Connecting to device... OK Model : XT1254 Bootloader : 0x7096 Baseband : MDM9625_41.51.07.22.04R QUARK_CUST Build : Blur_Version.24.91.5.quark_verizon.verizon.en.US Android : 6.0.1 Resetting FRP... OK Searching for Device in FastBoot Mode... OK Removing Factory Mode... OK Operation Finished. Elapsed Time: 02:30 [Module Ver. 4.8] |
The Following User Says Thank You to obaid mobiles For This Useful Post: |
02-26-2018, 15:32 | #699 (permalink) |
Junior Member Join Date: Apr 2014 Location: Sydney, NSW
Member: 2168905 Status: Offline Thanks Meter: 36 | Alcatel U3 4055T Successfully Unlocked Selected connection metod: FLASH Mode Exe version: Avengers Box MTK 0.4.8 Selected model: MT6571_EMMC Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM46) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 2. ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48384731 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED MODEL FROM PROINFO: 4055T-2BVDAU1 OTP IMEI: 359335080015727 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 35574126 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 35574126 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. [0]Unlock finished. CHK updated ok. Wait untill phone will start charging. All done. |
03-05-2018, 05:56 | #701 (permalink) |
No Life Poster Join Date: Jul 2015 Location: INDIA Age: 34
Member: 2431049 Status: Offline Sonork: 100.1680262:hunnyck Thanks Meter: 966 | zte-b815 unlock done [URL=""][img]https://i.imgur.com/BEaTf78.jpg |
The Following User Says Thank You to hunnyck For This Useful Post: |
03-05-2018, 13:41 | #704 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | OPPO A37 - Forgotten pattern read & removed without data loss Code: Operation: Read Pattern Searching for phone..... FlashMode Detected. Hello received. HW ID: 00000000E1507000 MSM8916 PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998421ADAD42A380F Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 14.56 GB Partitions count: 38 Userdata Size: 11.02 GB Manufacturer: OPPO Cpu: arm64-v8a Build Id: LMY47V Model: A37f Android Release: 5.1.1 Android Version: A37fEX_11_170701 Config: diag,serial_smd,rmnet_bam,adb Security patch: 2017-06-01 1 2 3 4 5 6 7 8 9 Pattern: Pattern: 235874 ************************************* HEX: 277BD8F553EB08398276FB4F3EAB3D2FB4A8D8FD ************************************* Restarting phone..... ************************************* |
The Following 3 Users Say Thank You to EjazATF For This Useful Post: |
03-06-2018, 11:26 | #705 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2070856 Status: Offline Thanks Meter: 62 | huawei y520 repair imei done... Selected connection metod: Flash Connection Exe version: Avengers Box MTK 0.4.9 Selected phone: Ascend Y520-U22 Action : IMEI REPAIR. IMEI[1] for write : 866729029227722 IMEI[2] for write : 866729029277735 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SANDISK 0x53454d303447 EMMC FW VERSION: 3c:00:00:00:00:00:00:00 EMMC CID: 45010053454D30 : 000000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec600000 [3.693 GB] Preloader SEC version: 2 Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM9) Dumping data, wait. Reading imei IMEI[1]: 866729029227722 IMEI[2]: fffffffffffffff Backup saved: C:\Users\HP 6000\Documents\Android_MTK\nvram_backup\FLASH_MODE _NVRAM_MT6572_866729029227722_fffffffffffffff_03_0 6_2018_11_11_21.zip Writing imei IMEI[1] TO UPDATE: 866729029227722 IMEI[2] TO UPDATE: 866729029277735 Generic IMEI OK Wait untill phone will start charging. |
The Following User Says Thank You to toni_85 For This Useful Post: |
