Avengers Box (Multi Unlocker Box) |
09-16-2021, 11:28 | #1 (permalink) |
Freak Poster Join Date: May 2016
Member: 2573102 Status: Offline Thanks Meter: 21 | vivo s1 (1907) reset screen lock done without data loss But! apps aren't opening! Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.8 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(58) : MTK USB Port (COM58) [58] \\?\usb#vid_0e8d&pid_0003#5&2e2d6e34&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6768 CPU code: 707 Target config: e5 Secure boot enabled: true Need serial link authorization: false Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(58) : MTK USB Port (COM58) [58] \\?\usb#vid_0e8d&pid_0003#5&2e2d6e34&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6768 0 ca00 Using Algo 1. Helio MT6768 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6768 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010044563644 : 000000000000000000 EMMC UA SIZE: 0x1d1ec00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d20400000 [116.504 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(50) : DA USB VCOM Port (COM50) [50] \\?\usb#vid_0e8d&pid_2001#5&2e2d6e34&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Resetting userdata. [--0] writing to cache [helio]Please power phone in recovery mode(VOL +) to complete action. [0]All done. vivo s1 (1907) reset screen lock done witout data loss But! apps aren't opening! Error> (Loading app. Please try again later) any solution? |
09-16-2021, 13:40 | #2 (permalink) |
Member: 2573102 Status: Offline Thanks Meter: 21 | unable to access data! is there any other way to backup the data! because nothing works ! phone connects to pc even after allowing on phone storage not showing! Last edited by khankh; 09-16-2021 at 13:49. |
09-16-2021, 15:26 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This metod use phone api to perform reset and it's safe. It work like wipe from recovery, but directly. If exists problem like was described, this can be posible cause. 1.Phone have corupted firmware, in this case need to rewrite firmware. 2.Phone have read only emmc or bad blocks(need hardware repair) 3.Phone have activated frp, and need to remove frp also(on some phones this can cause stuck on logo) 4.Phone have corupted userdata, and need to make low level format, and allow phone to make initialisation(all data will be lost) |
09-16-2021, 16:01 | #4 (permalink) | |
Member: 2573102 Status: Offline Thanks Meter: 21 | Quote:
Firmware is ok Emmc is 100%ok I think the problem maybe caused by frp But I even turned on oem_unlock in developer setting restart the phone still not working-/! Old models like y93 on android version8 any vivo on android 8 or below works perfectly! Sent from my | |
09-16-2021, 17:19 | #5 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
This is not related to android version, exist problem with phone. Must be any from steps explained above. Try to reset frp, this will not lose data, if will not help you must try other solutions(with data lost). You can try some other, not sure if will help, but it's safe(not erase userdata). Try to load scatter firmware, untick all partitions, and write only cache in phone. And check after if phone will start. Last edited by orbita; 09-16-2021 at 17:25. | |
