04-09-2013, 12:39 | #1 (permalink) |
Major Poster Join Date: Jan 2013
Member: 1874977 Status: Offline Thanks Meter: 53 | FalWok For iPhone 5 GSM WCDMA Unlcok Sim card Work IOS 6.0 TO 6.1.3 3G About Software ,the FalWok adopts the Activation code and the patch installation,east to use .it supports any carrier in the world for iphone 5 .And we have mony default version unlock sim card .For example efault Sprint ,Verizon ,AU ,SB etc ...just play and plug .If you want to change other carrier ,you only to use the activation guide card to choose your iPhone carrier.The main advantage is that the Nano FalWok can work perfect for iphone 5 :CALL ,MESSAGE ,INTERNET all work perfect .the Nano FalWok Support all the iPhone 5 iOS version: iOS 6.0,iOS 6.0.1 ,iOS 6.1 ,iOS 6.1.2 ,iOS 6.1.3 etc... Nano FalWok advantage: 1.USES the market the most stable, power consumption minimum F981 chips; 2.FalWok adopts the New PCB, better contact, it will not shows No sim in your iPhone. 100% guarantee the quality no problem. Breaking the traditional design, the tail insertion design etc.... 3.FalWok Support all WCDMA 3G Sim Card in the world,Just install the patch is Ok, eary to install, no need to complex steps. 4.FalWok Work for iPhone 5 all operators ,and use original iPhone 5 Tray Change ,No color difference with iPhone 5 . 5.FalWok Support All Coutry ,and have some country default version ,such as :USA Sprint ,USA Verizon ,JP SB ,JP AU etc...just play and plug .If you want to change other carrier, you only to use the activation guide card to choose your iphone 5 carier. 6.Perfect and Easy packaging ,Perfect protection Chip and Tray . Quick Overview The FALWOK Ultra S GSM unlocks your GSM iPhone 5 running iOS 6.1.3! It's a true plug-and-play unlock for GSM iPhone 5 running iOS 6.0 - 6.1.3. The FALWOK Ultra S is a thin microprocessor that sits between your network SIM card and the base-band hardware, allowing you to use your GSM iPhone 5 on all worldwide GSM networks. FALWOK™ Ultra S Notice The FALWOK™ Ultra S for iPhone 5 iOS 6.1.3 does not fully support MMS functionality in GSM iPhones. Due to the way MMS settings are locks within iOS 6.1.3, there are limitations on manually inputted settings. iFunBot, IBackUpBot, and Jailbreak have been used in previous iOS versions to manually program SMS and MMS settings and circumvent this issue. Applenberry.com cannot guarantee a solution will be made available for this issue with the FALWOK™ Ultra S for iPhone 5 iOS 6.1.3. Details: GSM iPhone 5 Unlock: True Plug-and-Play Unlock with no Jailbreak required Unlocks GSM iPhone 5 running iOS 6.0 to iOS 6.1.3 iPhone 5 requires upgrading to the latest firmware 6.1.3 to get unlock. Works with Modem Firmware 2.0.10, 2.0.12 and 3.0.04,3.04.25, Works with all iPhone 5 SIM Cards, including FIDO, Germany T-mobile and other carriers with special SIM cards. No SIM Card Cutting or Physical Modifications No Need to Dial International Emergency Number 112 Low Power Consumption Custom SIM Tray Included 30 Day Satisfaction Guarantee New Verification Code for Genuine FALWOK™ Products Tray have White and Dark blue True Plug-and-Play Unlock Turbo SIM for GSM iPhone 5 Unlock your GSM iPhone 5 with the re-engineered FALWOK Ultra S GSM turbo SIM. Our new technology takes advantage of a new exploits that fully unlock your GSM iPhone 5. It’s true plug-and-play functionality with no jailbreak required for your GSM iPhone 4S/5, so just pop it in and start calling. Compatible with all GSM iPhone 5 SIM Cards The new FALWOK Ultra S GSM is now a single turbo SIM that “learns” your network, so there is no need to select a specific FALWOK Ultra S specific to your cellular service provider. Your new FALWOK Ultra S GSM turbo SIM comes in learning mode, but after inserting it into your iPhone 4S with your original SIM card, our technology learns your network types and settings for a true plug-and-play unlock solution. One caveat of this exploit is that, if for some reason you need to change your current SIM with a SIM card from a different carrier, you will need to reset your FALWOK Ultra S with the reset SIM included with your genuine FALWOK Ultra S GSM. Beware of other solutions that claim to circumvent this issue. It is simply not possible when taking advantage of this new exploit in the iPhone 5 firmware. No SIM Card Cutting or Physical Modifications The new FALWOK Ultra S GSM is engineered using an advanced chip set, which is more expensive but performs a whole lot better than cheaper solutions. We don’t manipulate, polish, or sand down cheaper microchips to make our SIM interposer small enough to fit, and there is no need for you to cut your SIM card or modify your iPhone 5 in any way. Beware of counterfeit FALWOK products claiming to use tbetter chip set and selling for less than our rock bottom pricing. Most people won’t be able to tell the difference by visual inspection, but some cheaper, larger chips used in counterfeit solutions are sanded, cut, or polished to fit into your iPhone 4S/5. These solutions expose sensitive electronic components and are notoriously prone to overheating, short-circuit, and breakage. Guaranteed Better Reception than Last Generation Unlocking Solutions Now that we no longer take advantage of the old exploits, we’ve re-engineered the FALWOK Ultra S GSM for enhanced signal strength with strong, consistent voice and data communication. Now there is no compromise in reception when choosing genuine FALWOK products. No Need to Dial International Emergency Number 112 There is now no need to dial the international emergency number (112) during installation or when rebooting your iPhone 4S/5. Our learning technology allows for true plug-and-play iPhone 4S unlock solution. Beware of solutions that require you to dialing an emergency number. This may violate telecommunication abuse policies and may lead to service cancellation on some networks. Decrease Power Consumption The new chip set in our new FALWOK Ultra S GSM is engineered to operate under the 3-volt standard. That means your battery will last just as long as it would without the FALWOK Ultra S. Beware of counterfeit solutions claiming to use a similar chip set. We’ve invested the time and money to engineer our new FALWOK Ultra S GSM with better power efficiency. This kind of technology can’t be duplicated or implemented on cheaper chip sets. 30 Day Satisfaction Guarantee If our FALWOK Ultra S GSM turbo SIM meets our terms and conditions but doesn’t work on your iPhone 4S, simply send it back with its original packaging and your original receipt for a full refund. |
The Following User Says Thank You to falwok For This Useful Post: |
