Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 11-22-2014, 08:04   #1 (permalink)
Member: 1916471
Sonork: 100.1637842
Thanks Meter: 63
Thumbs up karbonn A66 New Type Off Lock help me Forum Members
I have This Problem Soluction Pls
IM Try hard reset DONe... Not Solv ....
Old 11-22-2014, 13:28   #2 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
do you full flash og file and tool do you Search on
Old 11-22-2014, 15:33   #3 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
First Format With Any Chines Tool.
Then Flash With This File : c3b-qy-c3-hvga-lca_a66_gg-android4.4_UTLA66v1013_release By MMC.
Old 11-22-2014, 17:16   #4 (permalink)
Member: 1916471
Sonork: 100.1637842
Thanks Meter: 63
Problem solv.....
Thanx To SSS MOBILE SOLUCTION watsapp groub
Old 11-27-2014, 12:12   #5 (permalink)
Member: 1062735
Sonork: 01410169
Thanks Meter: 9
i need karbonn a66 flasher&file
Old 11-27-2014, 12:27   #6 (permalink)
Member: 1761266
Thanks Meter: 79
Originally Posted by babamobilecares View Post
Problem solv.....
please share your solution with forum members
Old 11-28-2014, 11:38   #7 (permalink)
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
found only run user data Problem solve not hard reset
Old 11-28-2014, 13:26   #8 (permalink)
Member: 1576733
Thanks Meter: 622
Same Lock Found in Colors Xfactory X45
Colors xfactor X45 is EMMC Device (MTK 6572 I th ink). This device has USB DEBUGGING was Off. Fast Boot Mode OFF. Modem Not detected. If you format, then, you can open the Menu and you can do USB debugging ON but after 15 second, it will locked like you shown in the picture and the USB Debuggin you made few moment ago, will be OFF.
You can't solve this problem
doing:
1. Formatting
2. Hard Resetting or
3. Flashing
I think no one has solution of such problem except EMMC Boxes.
Diosa
The Following User Says Thank You to diosa For This Useful Post:
Old 12-22-2014, 11:15   #9 (permalink)
Member: 2272083
how to privacy code unlock....
Old 12-22-2014, 15:49   #10 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Please Use Search Button Before Post.
Click Here For Solution.
Test, And Post Results.
Page generated in 0.19379 seconds with 8 queries
