02-03-2013, 18:13 | #4 (permalink) |
Freak Poster Join Date: Apr 2008 Location: India-Tamilnadu
Member: 747158 Status: Offline Thanks Meter: 13 | volume up+power 5 sec ...........100% done Not working bro... after press volume up+power show Factroy test below Full Phone Test Item Test View Test Result Exit |
02-03-2013, 20:04 | #5 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | I have orignal flasher and flash file but the phone doesnt detect on original flasher. I think it needs modified cable instead of normal micro usb. As it is described in service center website "Use special cable to upgrade this phone". But cable schematic is not provided, only file and flasher is given. |
02-04-2013, 15:12 | #6 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 713765 Status: Offline Thanks Meter: 41 | 100 Volume Down + Menu key + Power key select option with volume down key wipe data/factory reset & use power key for select select option with volume down key yes -- dalete all user data & ur problem 101% solve. |
02-04-2013, 15:12 | #7 (permalink) |
Member: 713765 Status: Offline Thanks Meter: 41 | Volume Down + Menu key + Power key select option with volume down key wipe data/factory reset & use power key for select select option with volume down key yes -- dalete all user data & ur problem 101% solve. |
04-06-2013, 15:17 | #10 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Hello, use Android Multi Tools v1.02b this tool, very easy to remove pattern lock & Google A/C. B.R., B.Uttam |
The Following User Says Thank You to uttam4u2002 For This Useful Post: |
04-29-2013, 07:08 | #12 (permalink) | |
Major Poster Join Date: Oct 2008
Member: 886441 Status: Offline Sonork: 989090 Thanks Meter: 4 | how to Karbonn A1+ g/c problem Quote:
The Following User Says Thank You to ritesh_ritesh75 For This Useful Post: |
06-06-2013, 06:33 | #13 (permalink) | ||
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Quote:
B.R., B.Uttam | ||
09-03-2013, 13:59 | #14 (permalink) |
Freak Poster Join Date: Mar 2010 Location: IN MY GIRLFRIEND'S HEART
Member: 1274132 Status: Offline Thanks Meter: 20 | SOLUTION FOR KARBONN A1+ PATTERN LOCK / FLASHING.. THINGS U NEED .... 1. VOLCANO BOX 2. KARBON A1+ FLASH FILE 3. UPGRADE DOWNLOAD (GREEN SPREADTRUM FLASHER) 4. SPREADTRUM DRIVER CHECK YOU KARBONN A1+ SOFTWARE VERSION SEE BACK LABEL... YOU CAN SEE THERE IS SW VERSION: 2.0.8 ,2.0.7 OR 2:0.3, 2.0.2, 1.0.9 ETC. DOWNLOAD FILES FROM SUPPORT WEBSITE ...HERE 1 STEP OPEN VOLCANO SOFTWARE(USE ANY VERSION) CONNECT YOUR PHONE GO TO DETECT TAB SELECT SPD/ANYKA CLICK DETECT BUTTON PRESS CONTINOUSLY VOLUME UP BUTTON OF PHONE .. YOU WILL SEE IN RIGHT SIDE WINDOW SPD DETECTED... AFTER DETECTED MINIMIZE THE VOLCANO SOFWARE OPEN UPGRADE SOFTWARE CLICK ON LOAD PACKET BUTTON (BIG ) SELECT FILE ... SELECT HW INFO.... (INCLUDED IN FIRMWARE) CLICK START DOWNLOADING BUTTON REMOVE ONLY CABLE FROM PHONE THEN REPLUG DOWNLOADING WILL START ... AFTER FLASHING COMPLETED YOU WILL SEE PASSED SHOW IN FLASHER.. REMOVE YOUR CABLE YOUR PHONE SUCESSFULLY FLASHED .... IF YOU FOUND ANY PROBLEM OR ANY REQUEST POST HERE .... BR. ARMAN RAZA |
10-10-2013, 07:46 | #15 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Tiruvannamalai,Tamil Nadu
Member: 450110 Status: Offline Thanks Meter: 187 | A1+ Quote:
http://forum.gsmhosting.com/vbb/f824...sh-ok-1725550/ | |
The Following User Says Thank You to jaijee For This Useful Post: |
