Karbonn A51 Pattern lock / hard reset solution How to remove karbonn A51 Pattren lock |
1. Charge the battery 100%. 2. Turn off the phone. 3. Turn ON the device by pressing and holding the VOLUME UP key and the power key together until the phone shortly vibrates. 4. When Android system recovery menu appears, release VOLUME key. 5. Highlight wipe data/Factory reset using volume key. 6. Confirm with Power or Cancel using BACK key. 7. After hard reset is done, highlight reboot system now and confirm your selection. Note! All data will be deleted! BR Alex |
not work in my set only see recovery system logo |
A 51 Karboon hard reset key not work bro please help ... |
please any one help me A 51 Karboon hard reset |
not working please help give me 100% solution |
karbonn a51 unlock gpg dragon is best,spd,format only user data ,done |
here ur sulitoin bro kindly check it http://img661.imageshack.us/img661/8364/oIK4R2.jpg Quote:
Kabonn A51 pattern unlock any one help plez without tool and box |
Here It's, Karbonn A51 Hard Reset Method/Solution, Use Without Any Box & Without Any Risk. http://forum.gsmhosting.com/vbb/10825463-post2.html http://forum.gsmhosting.com/vbb/10779228-post4.html Post Result Please. |
karbonn a51 how the hard reset |
There Is No Way For Hard Reset To Karbonn A51. Use This Version Flash Tool : ResearchDownload - R2.9.7005 And Use Any Version Flash File : DOWNLOAD First Select Flash File Any Version By Load Packet Then Click On Settings & Deselect All Files From Main Page. Only Select UserDate. Then Click On OK Last On Click On Start Downloading. You'll See "Passed" With Green Colour In Flash Tool. |
some model 51 flashing,hand format box not support use flash tool,but same model support hand format or box many time am tested........ |
There Is Two Model & Many Versions For A51 & A51+. Hard Reset Only Work On A51Plus, Not Work On A51. A51Plus Have MediaTek & A51 Have SpreadTrum CPU. |
