11-18-2013, 00:53 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 58
Member: 947561 Status: Offline Thanks Meter: 14,052 | There is a recovery procedure available (thanks xda) Welcome to the ./downloads/Karbonn/A9plus/ folder of the support area for your service center Just try it BR Alex |
11-20-2013, 09:39 | #5 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | Quote:
Its giving error cookie if present not received i think it neds to get boot repair do u have the pinouts for jtag or any dump or any solution | |
11-21-2013, 16:05 | #6 (permalink) | |
Freak Poster Join Date: May 2008 Location: gujarat ind
Member: 773986 Status: Offline Thanks Meter: 52 | Quote:
cookie if present not received any solution? or mobile return to customer? help | |
12-19-2013, 11:00 | #10 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | QPST 2.7 build 399QPST-2.7.399 BP Firmware BP_JB_Firmware drivers ICS_pcdrivers drivers JB_pcdrivers Install QPST 1. Extract QPST-2.7.399.rar. Run SETUP.EXE 2. Run SETUP.EXE, press INSTALL when it prmpt to insall additional Visual C++ runtime libraries. Follow the defaults, press NEXT until it is finished with the install. Install drivers 1. Connect deadboot flare to PC / Laptop. 2. Go to device manager, expand PORTS (COM & LPT). Check if there is an item called Qualcomm HSUSB QDLOADER 9008. If the item is there, you are done with driver install. If it does not exist, proceed to step3. 3. If there is no item under PORTS (COM & LPT), check device manager under OTHER DEVICES > Unknown Device 4. Double click UNKNOWN DEVICE > UPDATE DRIVER > BROWSE MY COMPUTER > browse to the folder where you saved extracted the ICS / JB drivers. It will install the driver, if it prompts for unsigned drivers, press INSTALL ANYWAY. 5. It should now be listed under COM PORTS > Qualcomm HSUSB QDLOADER 9008. Run QPST and reprogram EMMC (this is where the magic begins) If you are on Win7, make sure you run it under compatibility XP Sp3 and RUN AS ADMINISTRATOR 1. Run EMMC SOFTWARE DOWNLOAD. 2. Press BROWSE, it will detect your phone. Look for the PHONE TAB that says DOWNLOAD. Press OK. 3. Put check mark on PROGRAM BOOTLOADERS, PROGRAM MMC DEVICE, TRUSTED. 4. Under FLASH PROGRAMMER FILENAME, enter MPRG8X25.hex 5. Under BOOT IMAGE, enter 8X25_msimage.mbn 6. Press LOAD XML DEF > navigate to your extracted JB firmware > select rawprogram0 > press OPEN. 7. Press LOAD PATCH DEF > navigate to your extracted JB firmware > select patch0 > press OPEN 8. PRESS DOWNLOAD 9. An warning message may appear, TIME OUT WAITING etc etc or COOKIE NOT RECEIVED. If the error is TIME OUT WAITING, press OK and then press SWITCH DEVICE TO DLOAD. Check the flare, it will show RESET FOR ENTRY QPST. 10. Exit EMMC SOFTWARE DOWNLOAD. Proceed to flash Jelly Bean BP Firmware and then flash Jelly Bean img dump. 11. IF ERROR IS COOKIE NOT RECEIVED, sorry it is still bricked. |
The Following User Says Thank You to Umesh_Arora For This Useful Post: |
12-31-2013, 11:05 | #15 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2095919 Status: Offline Thanks Meter: 0 | My android phone is dead. It is not starting up & not charging while charger ,data cable & battery are OK. Phone was not in use for 20-25 days & when try to on it, it couldn't start. I try to charge it but it was not showing anything(usual battery symbol). I left it on charging for 5-6 hours & again try to on it but it couldn't start. It is not showing anything like welcome screen & not giving any starting vibration. I tried power button+vol. up/down key but nothing happened. Now it is completely dead & its warranty period has been over. I took it to local repairer (not confirm whether had sufficient knowledge of android phones or not) he examined it said "its hardware is OK problem may be of of software." Then he went to another person. He tried to install its software (I think OS - ICS). According to him files were written but 2 files were creating problem in writing. He advised me to take it to the service center. Please help what to do. Phone details are: Manufacturer- Karbonn Model - A9+ OS - Ice Cream Sandwitch Processor - 1.2 GHz dual core (Snapdragon S4) |
