Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 12-25-2017, 09:01   #1 (permalink)
Crazy Poster
Member: 2601459
Thanks Meter: 9
Karbonn A41 Power Flashing Error
i have one set karbonn a41 power_v04 hang on logo
i am flashing with this firmware link below
https://drive.google.com/uc?id=0B7P4...xport=download
i am getting this error.... image below
https://imgur.com/bz938uy
i also try in miracle but miracle write error
also try in tool tick on erase all flash but no luck
device is on hang on logo
Old 12-25-2017, 10:45   #2 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Use This Version FACTORYDOWNLOAD_R19.17.4301_P1 Flash Tool : DOWNLOAD
__________________
Read The Rules Carefully!!!
WBR
MyGSM World.
The Following 4 Users Say Thank You to MyGSM World For This Useful Post:
Old 12-25-2017, 11:28   #3 (permalink)
Crazy Poster
Member: 2601459
Thanks Meter: 9
FACTORY TOOL ERROR.................
https://imgur.com/Bd5GywF
Old 12-26-2017, 15:54   #4 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
After Facing This Error Disconnect The Handset & Connect Again With Boot (Volume Down) Key.
Insert USB Cable Then Battery. Important Thing Is Do "NOT" Stop Or Close The Flash Tool After Facing An Error.
Post Result Please...
__________________
WBR
MyGSM World.
The Following 3 Users Say Thank You to MyGSM World For This Useful Post:
Old 12-26-2017, 17:22   #5 (permalink)
Crazy Poster
Member: 2601459
Thanks Meter: 9
Originally Posted by MyGSM World View Post
Dear Friend,
Sorry sir...... But now device is not my hand
Returned to customer....
And tnx for this useful info ....
Next time when i facing same isue in another spd device i definitely try this trick
Sent from my Redmi 3S using Tapatalk
Old 12-27-2017, 08:01   #6 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
yes many new karbonn spedtrum phones not getting flashed in research downloader. only service center people doing this hang issues.
if somebody knows the solution please post it
wbr
Old 12-27-2017, 14:10   #7 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear @bhuvanele,
Do You Have Karbonn A41 Power With Hang At Logo Problem? If Yes So Use Above Method.
If In Case Not Work So Post Here Please, We'll Provide You The Working Solution.
__________________
WBR
MyGSM World.
The Following User Says Thank You to MyGSM World For This Useful Post:
Old 12-29-2017, 05:35   #8 (permalink)
Member: 704971
Thanks Meter: 4
use modifi cable.or buy from the market
Old 01-02-2018, 08:05   #9 (permalink)
Member: 2378338
Thanks Meter: 3
karbonn a41 power flashing problem
stuck on system flashing
Capture_zpsu5yorkgu.png Photo by sajanbharavad | Photobucket
please help bro
Old 01-05-2018, 08:47   #10 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
after repairing it with FACTORYDOWNLOAD_R19.17.4301_P1 , use SPD_Upgrade_Tool_R4.0.0001 tool for flashing
wbr
The Following User Says Thank You to bhuvanele For This Useful Post:
Old 01-05-2018, 15:10   #11 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Don't Require To Use Other Tool Like You Wrote In Your Post.
Once Again Going To Write Procedure In Different Ways.
After Error Just Remove The Battery Then Press & Holding Volume Down Then Insert The Battery,
Again Error, Remove The Battery Then Press & Holding Volume Down Key Then Insert The Battery Again.
Important Thing Is "DO NOT STOP" The Flash Tool While Using Above Procedure.
__________________
WBR
MyGSM World.
The Following 2 Users Say Thank You to MyGSM World For This Useful Post:
Old 01-20-2018, 14:19   #12 (permalink)
Member: 614885
ur right sir after trying 4 and 5 times its working
Old 01-27-2018, 10:43   #13 (permalink)
Member: 1187075
Thanks Meter: 10
my handset is dead with this trial help me
after it saya re enter download mode it's even not connected to pc
Old 01-27-2018, 13:02   #14 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
What Was The Problem Before Flash?
Are You Sure You're Pressing & Holding Volume Down Key Before Connect To The PC?
__________________
WBR
MyGSM World.
Old 01-27-2018, 13:14   #15 (permalink)
Member: 1187075
Thanks Meter: 10
hang on logo and i also use shorting cable n volume down press n battery is fully charged 4.0v
The Following User Says Thank You to milanlove For This Useful Post:
Page generated in 0.18476 seconds with 8 queries
