![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: Infinity-Box Support-
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,363 ![]() | Just unlock BL. Put phone into fastboot mode, install adb drivers and type " fastboot oem unlock" in cmd window and press vol up button on phone. Don't forget to lock BL again by typing " fastboot oem lock" Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
![]() | #4 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: May 2015 Location: delhi
Member: 2399967 Status: Offline Thanks Meter: 13 | Try this Download ADB Fast Boot DriverHere * 1st put yur mob in fastboot mode by holding vol up+ pwr (for choose option use vol up for select vol dwn) * Open adb folder hold shift right to open command window here *Enter Below given command Fastboot devices (check mobile detected or not 1st) fastboot oem unlock (check yur mobile to select ) fastboot format userdata fastboot reboot |
![]() | #6 (permalink) |
Member: 2399967 Status: Offline Thanks Meter: 13 | Add the Command Prompt to the Windows Explorer Right-Click Menu A hidden functionality in Windows allows you to right click on a directory, and select “Command Prompt Here” from the menu. Here’s the registry hack to get this working. Make sure you back up your registry just in case. I’ll show you the step-by-step method, but you can skip down to the bottom for the alternate reg file. Step-By-Step Method: Type regedit.exe into the Start\Run dialog, and then navigate to the following registry key: HKEY_CLASSES_ROOT\Directory\shell Once you are at that key, right click and choose the New Key option: Name the key “CommandPrompt” without the quotes and then double-click on the default value. Change the text to “Command Prompt Here” as seen here: Right click on the new Command key and select New key, as you did before. Name the new key Command as well, and then double-click the default value of that key. Set the text of that key to this: cmd.exe /k cd %1 You can see what it should look like here: Now when you right click on the folder, you should see this dialog: That will open up a prompt like this: Alternate method: You can create a text file named anything.reg, and insert this text into it: Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\Directory\shell\CommandPrompt] @=”Command Prompt:” [HKEY_CLASSES_ROOT\Directory\shell\CommandPrompt\Co mmand] @=”cmd.exe /k cd %1″ Double click on that file, and the text will be entered into the registry, and you’ll have the same right click command prompt. |
The Following User Says Thank You to shivampal For This Useful Post: |
