Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > 2G Latest Models
2G Latest Models Models made in 2011, 2012, 2013 year.
Old 09-06-2012, 21:24   #16 (permalink)
Member: 201395
Thanks Meter: 4
e2220 flashing
e2220 flashing 1+5
work succesfull
test by me
The Following User Says Thank You to __tito__ For This Useful Post:
Old 09-13-2012, 13:08   #17 (permalink)
arjun-kumar's Avatar
Member: 1379824
Thanks Meter: 26
Originally Posted by acarelectronic View Post
flash mode
A+Q
1+ALT lock key
1+3
2+5
thanks 1+ALT lock key is working 100%
Old 10-09-2012, 12:09   #18 (permalink)
Fragga's Avatar
Member: 1507693
Thanks Meter: 131
i need drivers for this phone E2222,URGENT PLIZ
Old 11-01-2012, 15:36   #19 (permalink)
gj7
Member: 1705262
thanks bro.... i tried it with 1+5 working 100%%%%%%%%%
Old 11-02-2012, 05:21   #20 (permalink)
Member: 1832955
Thanks Meter: 2
check for drivers in google you will definitely find some answer for your question there.
Old 11-04-2012, 07:43   #21 (permalink)
Member: 1684564
Thanks Meter: 25
flash mode
A+Q
1+ALT lock key
1+3
2+5
all try sir but not conected only rj45 conected full erese and flash e2p write but but set is blinkin
Old 11-06-2012, 06:13   #22 (permalink)
Crazy Poster
Member: 480580
Sonork: dadzki1234
Thanks Meter: 5
a+s works for me..thank you mate
Old 12-20-2012, 13:43   #23 (permalink)
Member: 178616
Thanks Meter: 90
Arrow E2222 conecting probling
After alot of tries finally i connect it by pressing 1+3 buttons at same time and insert usb cable without battery
Old 12-28-2012, 10:12   #24 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
2+5 without battery worked for me for flashing with flashloader 7.4.7......!
Old 12-29-2012, 12:26   #25 (permalink)
Member: 1270383
Thanks Meter: 7
a+s without batt 100000000000000000000000000000000000000% working
Old 12-29-2012, 12:38   #26 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
Firmware Update Process:
1.- First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed
2.- Power on the phone and connect USB cable to it and to PC to let Windows install its drivers.
3.- Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers.
4.- Run the E2222 Ch@t Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe
5.- Click SET MODEL button and select: E2222_TEXTO_Setting_v00.mdl
6.- For Application Binary File select: E2222xx.ptt
7.- For Tfs file select: E2222xxxxx.tfs
8.- For CSC file select: E2222Oxxxxx.csc
9.- Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers.
10.- Disconnect the phone after DFU drivers installed.
11.- Click START button and reconnect USB cable to phone while pressing Q + A keys.
12.- The program will detect it and start the Update Process so wait till all is DONE.
13.- Disconnect the phone and turn it on then do Full reset: *2767*3855#
Old 02-15-2013, 15:27   #27 (permalink)
pal mobile's Avatar
Member: 440801
Sonork: 100.1604292
Thanks Meter: 44
Thanks to all respectable members
CONECT USB CABLE BY PRESSING A+Q
TESTED BY ME
Pal mobiles
Old 02-22-2013, 14:53   #28 (permalink)
Member: 1493682
Thanks Meter: 12
Samsung E2222 flashing solution
A+S this is correct combination for putting handset in dfu mode tested by me.
Old 03-09-2013, 14:47   #29 (permalink)
msmobile's Avatar
Member: 253882
Sonork: 100.1585698
Thanks Meter: 242
Press Q + W Key And Plug USB Cable.
Old 04-16-2013, 15:15   #30 (permalink)
Member: 614373
Thanks Meter: 2
A&S WORK.. thank you.
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.23714 seconds with 9 queries
