2G Latest Models Models made in 2011, 2012, 2013 year. |
03-13-2014, 17:09 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Samsung GT C3222 Flashing program here: http://forum.gsmhosting.com/vbb/12823162-post8.html Firmware: C3222JPJK7(THR)_Tsar3000.com - Download - 4shared Last edited by ...:::::NP™:::::...; 12-05-2017 at 06:05. Reason: link has been correction |
The Following User Says Thank You to gcceleghg For This Useful Post: |
03-13-2014, 17:12 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Firmware Update Steps: Run Samsung C3222/Ch@t 322 Download Program. Press OK . Remove and reinsert battery from the Phone and Press Volume Down + SIM Cards key then Connect it to USB cable. When PC ask you for Drivers install it ( Drivers are located inside Flasher Folder ). After all Drivers are installed disconnect the phone. Click on SET MODEL Button and select : C3222_PUNCH_Setting_v00.mdl file. At the field Application binary file click on Browse and select : C3222OPEN.ptt file. At the field TFS file click on Browse and select C3222xxxxx.tfs file. At the field CSC file click on Browse and select C3222Oxxxxx.csc file. Click on START button. Remove and reinsert battery from the Phone and Press Volume Down + SIM Cards key then Connect it to USB cable. Wait till the process finished. When all is done the program give you this : Slot freed for new download. Disconnect the phone and turn it on. |
12-05-2017, 06:01 | #8 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Hi, sometimes old gold is used You can download from here, Mega link:===> C3222 Flash loader 7.4.7_ssg_v0.0_lite(loaderupdated_punch) + Firmware 4shared link===> C3222 Flash loader 7.4.7_ssg_v0.0_lite(loaderupdated_punch) + Firmware RAR PASS:- gsmhosting
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 12-05-2017 at 06:07. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
