02-28-2023, 13:25 | #1 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | ALCATEL JOY PAD 2 NETWORK UNLOCK Failed HELP [ANSWERED] Code: Exe version: NCKDongle AndroidMTK 2.8.3 Selected model: 0-By CPU AUTO Phone must be off with battery inside. Battery must be charged Please insert USB cable now... Keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#5&3ad613e9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6761 CPU code: 717 Target config: e7 *********************** Secure boot enabled: true Need serial link authorization: true Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3b200]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_apollo84gtmo.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#5&3ad613e9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6761 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68423861 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(4) : MediaTek DA USB VCOM (Android) (COM4) [4] \\?\usb#vid_0e8d&pid_2001#5&3ad613e9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [0]IMEI not found in nvram file. Phone have OTP partition. MODEL FROM PROINFO: 9032Z-2ATBUS7 SECRO FROM PROINFO: 41C5UPY3DM00 OTP IMEI: 015774009693683 Modem version: MOLY.LR12A.R3.TC5.PR2.SP.V2.P9 [Helio]Reading security, wait... [Helio]Unlock is not supported for this model [helio]Wait untill phone will start charging. [0]All done. Exe version: NCKDongle AndroidMTK 2.8.3 Selected model: 0-By CPU AUTO Phone must be off with battery inside. Battery must be charged Please insert USB cable now... Keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#5&3ad613e9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6761 CPU code: 717 Target config: e7 *********************** Secure boot enabled: true Need serial link authorization: true Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3b200]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_apollo84gtmo.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(3) : MediaTek USB Port (COM3) [3] \\?\usb#vid_0e8d&pid_0003#5&3ad613e9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6761 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68423861 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(4) : MediaTek DA USB VCOM (Android) (COM4) [4] \\?\usb#vid_0e8d&pid_2001#5&3ad613e9&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [0]IMEI not found in nvram file. Phone have OTP partition. MODEL FROM PROINFO: 9032Z-2ATBUS7 SECRO FROM PROINFO: 41C5UPY3DM00 OTP IMEI: 015774009693683 Modem version: MOLY.LR12A.R3.TC5.PR2.SP.V2.P9 [Helio]Reading security, wait... [Helio]Unlock is not supported for this model [helio]Wait untill phone will start charging. [0]All done. |
