06-06-2020, 16:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2004
Member: 60337 Status: Offline Thanks Meter: 13 | please help I have got this error Tecno F2 8+1A [ANSWERED] Exe version: NCKDongle AndroidMTK 2.6.9 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM185) Boot mode: Brom BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... [emmi]EMMC CID: 150100464E36324D42 Second stage DA fail, aborting [S_FT_ENABLE_DRAM_FAIL]Exe not support this emmi settings Please load scatter and preloader from phone fimware BBCHIP MT6580 flash id: 460001154D32364E9F Boot Fail.!!!. [0]All done. |
06-06-2020, 19:38 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In this case, if you want to do some, you must load scatter+ preloader. Exe complain about missing flash id in database. If you perform flash, you using wrong frirmware, in this case preloader. |
06-07-2020, 09:22 | #4 (permalink) | |
Member: 60337 Status: Offline Thanks Meter: 13 | Tecno F2 8+1A Quote:
can you gave some explanation on how to load scatter+preloader ? | |
06-07-2020, 09:54 | #5 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am not sure how you want to repair phone if you not know so basic things. Anyway, check atached screenshot, lets hope it will help you. |
06-08-2020, 07:13 | #6 (permalink) |
Member: 60337 Status: Offline Thanks Meter: 13 | Tecno F2 8+1A Thank for replay , I know the basic ,I receive a dead phone so when i try to read info in flash mode ,write flash firmware I have got the same error , I have try efferent firmware nothing work |
06-08-2020, 08:24 | #7 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | If you get same error with firmwares, this can meen hardware damage or problem with flash ic. Try to make debug log, in this way you can get more details about problem. |
10-17-2021, 18:15 | #8 (permalink) | |
Freak Poster Join Date: Aug 2016 Location: pakistan
Member: 2607003 Status: Offline Sonork: 100.1667344 Thanks Meter: 78 | S_FT_ENABLE_DRAM_FAIL]Exe not support this emmi settings Quote:
this is cpu problem rebol cpu or replace cpu dram pins are not working properly BEST REGARDS RANA WAQASS | |
